Resolved ff4 questions
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by savagcl, 2011/04/03.
  1. 2011/04/03
    savagcl Lifetime Subscription
    Is it possible to move the home icon back to the left side of FF?
    Is there a way to change the "Page forward" and "Page back" colors (each time
    i look at them, i think they are greyed out (or ate new themes for 4.0 out yet?
    thanks,
  2. 2011/04/03
    Bmoore1129
    Bmoore1129 Geek Member
    I think this is what you mean.
    Rt click on the home icon and select customize. Drag the home icon to the open customize window and drop it. Grab the home icon from the customize window and drag it wherever you want it.
    I use the Strata theme and the back and forward are blue if there is a back page to go to and light blue if there is none to go to.
    HTH
    wildfire likes this.
    wildfire
    wildfire Getting Old
    Cheers Bill,
    I'm pretty sure that'll work for Clif, It worked for me :)
  5. 2011/04/03
    Worked like a charm!!
    Thanks a bunch,
  6. 2011/04/04
    Westside
    Westside Inactive Alumni
    Thanks guys. I had not, even, found the item, until you pointed it out.
  7. 2011/04/04
    wildfire
    It does appear to be a strange decision to move the home link to the right by default Westside. Normally when you think home you look top left :confused:
  8. 2011/04/04
    Yes, strange! Kept throwing me off stride. I moved it
    to the same level as the bookmarks bar, no problem
    when you guys/gals tell me how it can be done.......
  9. 2011/04/04
    leushino
    leushino Well-Known Member
    I have to admit that I've sort of grown attached to it on the right hand side but I'm glad we now know how to move it back if need be.
  10. 2011/04/06
    JSS3rd Lifetime Subscription
    JSS3rd Geek Member
    FWIW, you can right-click anywhere in the menu or navigation toolbars (except the URL and search windows) and select Customize. Also, it's not necessary to drag a button into the Customize Toolbar window before moving it ... after Customize is selected, any button can be dragged directly to the desired position.
  11. 2011/04/06
    Bmoore1129
    Thanks Jim,
    So clicking customize unlocks the toolbar so the icons can be moved around. That sounds more logical than the longer method.
  12. 2011/04/06
    JSS3rd Geek Member
    Hi Bill,
    It's been that way in every version of FF I've ever used. I'm surprised that more users aren't aware of the fact. Or, maybe a lot of users don't even bother to customize FF.
    As far as I'm concerned, the Home button is useless. My home page is blank, and I never have more than a few tabs open at any given time. I'd much rather work from bookmarks instead of having a bunch of tabs load whenever I open the browser. Different strokes, I suppose ... it's all in what you get used to, and what works best for you.
  13. 2011/04/06
    leushino
    I like a home page... a portal as it were to the internet. Mine has always been Yahoo news which is customized to my taste. That way the first thing I see when I go online is the weather for my area, the headlines and any e-mail from family and friends. I would see a "blank page" as a bit useless, myself. To me... you have to go somewhere when you go online and if your first click is simply to a blank page "before" you head off to wherever it is you are going, I would see that as a wasted step.
  14. 2011/04/06
    my home page is google simply because it loads fast and i'm normally wanting to search for something....
  15. 2011/04/06
    JSS3rd Geek Member
    My "home page" is a blank page ... FF opens that way so no clicking is necessary, and there's no wasted step. I agree that you have to go somewhere when you go online, but I never know where I'll want to go first.:)
    As I said, it's all in what you get used to, and what works best for you.
  16. 2011/04/06
    Westside
    That's the spirit. But, in my case, I tend to go to this site, or another newsgroup, as well as one other site. So, I open the home group, with two tabs. But, it would work just the same opening with a blank page, and using a bookmark. I think that I have never exceeded four tabs, and, now only two are opened.
    I heard of people having memory usage of 1 GB with Firefox 4. I consider it obscene if it exceeds 120 MB
