Fdisk problem
Discussion in 'Windows XP' started by marty, 2004/07/19.
  1. 2004/07/19
    marty
    marty Inactive Thread Starter
    I've got a hd which had been running on a linux machine which I've added to my windows box. Went into dos tried to run fdisk... found a primary and secondary partition with three logical partitions on the secondary.
    Fdisk can't show me information on or delete the logical partitions so I can't figure out how to use any of the space on the secondary partition which is most of the hard drive.
    Marty
  2. 2004/07/19
    Christer
    Christer Geek Member Staff
    Download Delpart.exe and add it to a Win98 start disk.
    Start the computer from the Win98 start disk and run delpart.exe which will identify Your drives.
    Delete any partition that You'd like to get rid of.
    I would, as a precaution, disconnect the primary HDD for this operation. Then nothing can go wrong.
    Christer
    Edited:
    Came to think of that the tool is for removing NTFS partitions and I'm not 100% sure it will work on Linux partitions but I think so.
    marty
    Christer,
    Thanks for the tip, it's all worked out now. Didn't realize this was a known problem with linux hd's - so now I know. :)
  5. 2004/07/19
    Not exactly a problem w/ the linux drives, but the problem is that windows fdisk cannot recognize and/or partition linux filesystems such as ext2 & 3.
    For future reference:
    When encountering the same issue again you can boot from a linux install cd and run cfdisk, or a linux floppy w/ cfdisk on it. You can then delete the partitions and change the freespace to fat32. Then reboot & use windows fdisk.
  6. 2004/07/19
    Christer
    Marty,
    You're welcome ...... :) ...... !
    Did You use delpart.exe to remove the Linux partitions? I've just got to know ...... :confused: ......
    Christer
  7. 2004/07/19
    marty
    Sorry I didn't explain. Yes I downloaded delpart.exe from the Texas guy's page - even sent an email thanking his boss like he asked... what a hoot. Added it to my W98 boot disk and it was real easy to use. Then went into fdisk and all was well. Now I have an extra 6 GB on my office network.
  8. 2004/07/20
    Christer
    Good to hear!
    Now I only have to remember that delpart works with Linux partitions as well ...... :rolleyes: ...... !
    Christer
