failover script
Discussion in 'Networking (Hardware & Software)' started by adjad, 2010/06/21.
  1. 2010/06/21
    adjad
    adjad Inactive Thread Starter
    Hello!
    I use two simultaneous connections of INTERNET; one by modem ADSL and
    one by modem CDMA using a serial port COM1.
    I need to find a script (or either solution) to make a basculement between
    the two connections.
    Besides, for do that I need to define the adsl connection as prior because
    Windows xp took automatically the CDMA connection as prior. I tried this in
    advanced settings of the network connections in the control panel, but it
    didn't work.
    Best regards !
  2. 2010/06/22
    basculement?
    basculement is French - the translation, according to Google, is toggling, so .....
    would become ....
    I need to find a script (or either solution) to toggle between
  5. 2010/06/22
    adjad
    Yeah !
    ...For doing the load balancing between the Two connections with the ADSL as main
    connection.
  6. 2010/06/22
    Afraid that is as far as my input goes - this is not my area of expertise :)
  7. 2010/06/22
    Scott Smith
    Scott Smith Inactive Alumni
  8. 2010/06/22
    ephemarial
    ephemarial Well-Known Member
    And for a single computer.
    Did you set the interface metric number in advance settings?
    For each network connection – Internet Protocol (TCP/IP) – properties- advanced- uncheck Automatic metric – and enter a number for the Interface metric.
    Lower the number greater the priority.
    For example my wired connection has an interface number of 20.
    If I plug in my USB wireless adapter that connection has a value of 10 and computer will automatically switch over to it.
    Unplug it and switches back to wired connection.
