Resolved external hard drive not showing up on computer
Discussion in 'Windows 7' started by bebuzz68, 2014/02/27.
  1. 2014/02/27
    bebuzz68
    bebuzz68 Well-Known Member Thread Starter
    I have two ext hard drives one a 3.5 the other 2.5, sata neither one shows up on my computers. I tried win 7 and wind 8.1, I plug them in the usb and it says your device is ready to use, but I can't find it. I looked in device mgr. and its there but I can't use it there, where its supposed to be there is only C:
    D: AND E: one is the internal hd the other is recovery and the dvdr.
    where can I find this.
  2. 2014/02/27
    Hi bebuzz68. If you click Start< and in the Start search box type Disk Management and hit enter does the external hard drive show up there?
    bebuzz68 likes this.
    bebuzz68
    yes it says disk 1 unknown , not initialized
  5. 2014/02/27
    What happens if you attempt to initialize the disk?
  6. 2014/02/27
    bebuzz68
    it says disk 1 online, but I still can't find it.
  7. 2014/02/27
    Is the hard drive showing as unallocated or is it using the FAT32, or NTFS file system?
  8. 2014/02/27
    bebuzz68
    unallocated
  9. 2014/02/27
  10. 2014/02/27
    bebuzz68
    that did the trick, thank you.
  11. 2014/02/27
    You're Welcome. :)
