Windows Vista External Drive maintenance
Discussion in 'Legacy Windows' started by fourdoor2041, 2009/11/24.
  1. 2009/11/24
    fourdoor2041
    fourdoor2041 Well-Known Member Thread Starter
    Is it necessary after performing a routine defrag and an error check of C-drive to then do the same to the external drives and the flash drives? As often, less often, never?
  2. 2009/11/24
    It just depends;)
    If they are hard drives vs. flash drive - the amount of data coming and going on and off the drive(s)...There pretty must isn't a perfect answer...
    Even If you ask 20 people about:
    You'll get 20 different answers;)
    Vista has an automated defragging system. You should find it is set to run during inactivity (like when the screensaver is on). Watch the HDD LED activity when you are not working on it and you should see tasks being carried out occasionally.
    If you set a short period between inactivity and going into Sleep mode, there won't be much time for background tasks to be carried out, then you might find that manual defragmentation is necessary.
    At the Start-Search bar, type in 'Task' and open Task Scheduler. It will tell you about the scheduled Defrags.
  6. 2009/11/26
    Athlonite
    Athlonite Inactive
    if the external drive is an HDD then yes by all means defrag it but if it's an flash drive then no you don't need to and the fact that it will shorten the drives usefull lifespan
