external case for internal CD-RW??
Discussion in 'PC Hardware' started by savagcl, 2005/06/25.
  1. 2005/06/25
    savagcl Lifetime Subscription
    Trying to locate an external case for a TDK (intenal) cd-rw.
    Had no luck finding one using google. Was hoping someone here could point me to the
    right direction/site that has such an item for sale.....
    Hate to let it go because it creates cd's so fast.
    TDk, CDW and Bestbuy dont show any.
    thanks,
    savagcl
  2. 2005/06/25
    Those are good sites to keep in mind, thanks.
    The cd-rw is originally for an internal bay using the molex(?) 4 pin power
    connection. Its losing its bay for a sound card front panel and there are no
    spare front bays left open. So i'm looking for an external case with internal
    connections........
    thanks again, I'll go through those sites again.
    savagcl
  5. 2005/06/25
    Russ
    Russ Well-Known Member
    Russ,
    sounds like i'll have to make my own case. No problem, make a wood case and drill a hole
    in the PC case for the power cable.
    thanks, guys,
    savagcl
  7. 2005/06/26
    All 5½ external drives will work fine with any internal cd drive. They have a built in 4 pin power connector and the 40 pin ribbon cable.
  8. 2005/06/26
    This is an Internal drive that i need to put into an Extrenal case.
    thanks,
  9. 2005/06/26
    I think Steve is referring to an external drive case rather than a drive - I took apart a Maxtor One Touch to replace the drive which failed when I dropped it :mad: and the standard molex power connector was there for the drive.
  10. 2005/06/26
    Russ
    If you don't need a case for the drive you can run it off of this. http://www.surpluscomputers.com/store/main.aspx?p=ItemDetail&item=CRD10181 IDE to USB 2.0 External Drive Cable SBT-UI235. That does not come with a connection for sound. As Steve said any 5½ internal CD drive will work in a 5½ external case. I did just the opposite of what you want to do. I got a good deal on a external firewire DVD+RW drive a few years ago. Took it out of the case and installed it in my computer.
    Russ,
    #9
  11. 2005/06/26
    Russ,
    Thank you, that looks like something i could work with.
    Its not a big chunk of money either (always nice).
    I'll follow up with them and see what happens.
    thanks again,
    savagcl
  12. 2005/06/26
    Steve,
    Looks good but, a question - The built-in power connector is 3 pronged, i assume that means
    it just need a power cable plugged into a wall socket and not the 4 wire (internal power
    connection)?
    thanks for the help/info,
    savagcl
  14. 2005/06/26
    Needs both - molex connector powers the drive from an internal power supply in the box which in turn is powered from wall socket via the external 3 pin connector.
  15. 2005/06/26
    Got it.
    thanks PeteC
  16. 2005/06/26
    I have one of these, comes in very handy when working on spare ide drives of any kind, including cdrw drives, and also is good when servicing another's system because don't have to remove the drive from the case.
    http://microcenter.com/single_product_results.phtml?product_id=0150634
    It comes with it's own power supply that connects to the power port of the ide device. It works flawlessly, xppro already contains the necesary drivers for it, but it comes with a cd & drivers for win 98's & Millenium.
  17. 2005/07/25
    Ok, Just to let folks know.
    I got the one from newegg and it works great.
    thanks for all the help.
    savagcl
