Explorer General Protection fault
Discussion in 'Legacy Windows' started by bigboscoe, 2003/07/22.
  1. 2003/07/22
    bigboscoe
    bigboscoe Inactive Thread Starter
    Whenever I open any folder or anything (I'm talking control panel or anything in "My Computer),
    I get an error message that says "
    This program caused an illegal opertaion and will shutdown. "
    When clock "Details" This is what it says,
    EXPLORER caused a General Protection fault in Module VGA.DRV at 0007:00001238.
    I cant connect online for support (I'm on my other computer).
    I'm using WIN98 SE
  2. 2003/07/22
    markp62
    markp62 Geek Member Alumni
    In Safe Mode if you cannot do this in normal.
    Start\Run, type in Sfc and press Enter. Select Extract one file from installation disk. Put C:\Windows\System\Vga.Drv into the little window and click on Start in Sfc. Another window opens, Restore from the WinCD or C:\Window\Options\Cabs if you have the Recovery CD and cannot find the windows install cab files. Follow the prompts.
    Allow to save the old file in C:\Windows\Helpdesk\Sfc and create the folder if necessary. You will be prompted to reboot in order to use the extracted file.
