expired newsgroup messages will not be removed
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by emlsr, 2004/03/22.
  1. 2004/03/22
    emlsr
    emlsr Inactive Thread Starter
    hi-
    i hv just installed mozilla 1.6 in accordance with ramona's recommendation. thus far it appears to be somewhat facter than ns 7.1.
    i had hoped that mozilla wud solve a problem i am having with newsgroups. when i get the message that a chosen message has expired and i attempt to click and remove all expired messages, the process appears to start. however, when it is complete, nothing has been removed. this was true in both ns 7.1 and mozilla.
    is there something i shud b tweaking to correct this?
    thanks for ur help !! emlsr
  2. 2004/03/23
    Ramona
    Ramona Geek Member Alumni
    Hi emlsr,
    I've been trying to recreate your Newsgroup problem, and can't! Each time I click on the link: Click here to remove all expired articles , the expired message is removed.
    You might try this and see if it might help:
    Close Mozilla and Quick Launch
    Open Windows Explorer
    Navigate to your Mozilla Profile's News\news.server.name folder
    See: Profiles Folder Location
    Delete all of the files in the folder except the hostinfo.dat file
    Open Mozilla Mail & Newsgroups
    Select: Edit | Mail & Newsgroups Account Settings | | Server Settings
    Highlight the Newsgroup you just edited
    Enter the number of headers you want to download
    Open the Newsgroup
    When the "Download Headers" dialog appears, check the "Mark remaining headers as read" box
    Wait for the headers to download, then go to the View menu and select
    Messages | Unread.
    If this doesn't help, and if you haven't tried to do so already, then I would remove all Newsgroups Accounts (if the problem occurs on all Newsgroups), close Mozilla, reopen Mozilla, and resubscribe.
    Ramona :D
    emlsr
    hi-
    sorry for the delay in responding, but i decided to try ur suggestions a number of times before advising that they had not changed things.
    the only change that i experienced is that when i limited the number of messages downloaded, there were many fewer expired messages included in the list.
    when u state that clicking the "click here to remove.......messages" removes the expired message, does it remove the one hilited or all expired messages as the wording suggests.
    thanks, emlsr
  5. 2004/03/29
    Ramona
    Hi emlsr,
    It should remove all expired messages, or it does here.
    Ramona :D
  6. 2004/04/08
    joeskys
    joeskys Inactive
    remove expired newsgroup mess
    Roamona: I've set it to remove mess over 30 days old. I used to get the option to remove expired mess. Some groups have mess 3-4 months old. Joe R
  7. 2004/04/08
    Ramona
    Hi Joe,
    For Netscape 7.1, when you look at your Newsgroups settings, under "Offline and Disk Space" which settings do you have enabled?
    Also how many messages do you download? This setting would be under "Server Settings ".
    Ramona :D
  8. 2004/04/09
    joeskys
    joeskys Inactive
    HI Romona: Download 20 mess.
    Not larger than 100KB; not older than
    30 days; Remove older than 30 days
    Occasionally, but not lately I got the option to delete mess that expiredd.
    Joe R
    PS: I'm using NS 7.0
