Expand Drive Partition Winxp Pro
Discussion in 'Windows XP' started by Frank McLean, 2008/11/25.
  1. 2008/11/25
    Frank McLean
    Frank McLean Inactive Thread Starter
    I bought my computer from a local technical who built it and partitioned the 160 GB HD drive into a 20 GB C drive and a 140 GB D drive. He said he did this to protect the programming from viruses. Now the problem is that although Winxp Pro is only about 7.5 GB, there are hidden files such as Application Data that is 3.6 GB and Local Settings that is 4.2 GB. This problem is made worse by the fact that many programs such as Adobe that won't allow you to install them to a drive other than C.
    Despite moving everything I can off of drive C, I only have 828 MB of free space left. Fee Space is now too small to run defrag or install System pack 3. While there are still a few programs I could move to drive D, they're so small the impact would be negligible. Meanwhile, the free space keeps shrinking. Before moving everthing meaningful that I could off of drive C today, programs were slow loading or couldn't load until I closed something else or a window wouldn't open, etc.
    There are programs that advertise that they can expand a partition size without losing information or damaging the system and that this can be done by a novice without technical expertise. Question is, is there a program out there that can do this reliably and live up to these claims? Does anyone have first hand experience with this?
    TIA,
    Frank
  2. 2008/11/25
    Partition Magic is a very popular program to do this.
    Regardless of which one you use-> BACKUP your important data first. One little hiccup and you can loose ALL of your data.
    Frank
    There is reliable software available to achieve what you want to achieve, but nothing is ever foolproof and a backup of your data is strongly advised before using.
    I occasionally use an old version of Partition Magic (prior to it being bought by Symantec (Norton)), but if I was buying again I would tend towards Acronis Disk Director on the basis that I currently use Acronis True Image for regular imaging of my C:\ drive - and it is not associated with Norton :)
    No doubt you will get other suggestions, but whatever you use ensure that you have a data backup in place first.
    BTW - have you moved My Documents off C:\ drive? If not .....
    To change the location of a special folder and simultaneously move the files, right drag the folder to the new location - in your case D:\ and select Move here.
  5. 2008/11/25
    Frank McLean
    Steve and Peter
    Thank you for your recomendations and suggestions.
    Peter, the folder that is causing most of the trouble is C:\Documents and Settings\1 which is 7.7 GB. This folder holds two hidden folders, Application Data that is 3.6 GB and Local Settings that is 4.2GB.
    I'm wondering if it is all right to try and move these hidden folders or do they have to be on drive C? And if I try to move them do I risk crashing my system and making it unworkable? Do you know the answer to these questions?
    TIA,
    Frank
  6. 2008/11/26
    Frank
    From what I read it is nigh on impossible - and extremely risky - to attempt to move Documents & Settings to another drive. MS publish a method of doing this at the time of installation, but that does not refer directly to XP.
    I suggest you bypass that idea completely and use one of the programs noted above to re-size your C:\ drive and to backup any data on the C:\ drive before doing so as insurance.
  7. 2008/11/26
    Frank McLean
    Peter
    It's not Documents and Settings I was thinking of moving, it was folder 1. Is folder 1 movable considering it has Application Data and Local settings hidden folders in it?
    Also, if I have to expand the C drive, since the hard drive is partitioned into C and D drives, I would assume that I would have to back-up both of these drives, since any expansion of C would take away from D. Is that correct?
    TIA,
    Frank
    P.S. I only use a computer and am not technically knowledgeable about computers, so expanding the partition would be my last choice. And even then, I would likely only do that if the program was easy to use and understand for a layperson. Otherwise I would expect I'd have to get someone knowledgeable in these matters to do it for me. But, time is running out for me as I'm now starting to experience a lot of problems loading files and computer can get very slow at times. I'm starting to fear a lock-up or an inability to boot-up. So, this matter has now become high priority.
  8. 2008/11/26
    surferdude2
    surferdude2 Inactive
    While pondering, take a look at your C:\Documents and Settings\1\Local Settings\Temp folder. Under normal circumstances, you can safely delete anything you find in that folder.
    You may also consider using some freeware tool such as ATF-Cleaner or CCleaner to free up some space that may be wasted by unwanted temp files.
  9. 2008/11/26
    Frank
    I am having issues with your situation .....
    I am not familiar with that folder entitled 1 - it is not a regular Windows folder which makes me suspicious as does the size of the two folders you note. Checking my Desktop which is heavily laden with installed software, etc the Docxuments & Settings folder is only 1.7 GB. I have conacted one of our malware analysists for a view on this.
    Yes.
    Partition Magic is very straightforward to use being Wizard based - I am assuming that it still is as I have an older version - maybe 5 years old and I would imagine Acronis Disk Director to be the same although as I posted earlier I do not posess the program. The manual can be downloaded here ....
    http://s4u.download.acronis.com/pdf/DiskDirectorSuite10.0_ug.en.pdf
    and the relevant section starts on page 14 - Increase free space wizard — enables you to enlarge a partition at the expense of unallocated disk space or other partitions.
    In the meantime to gain a little breathing space clear out your Temporary files ....
    Start > Run > type in %temp% > Enter. All files and folders can be safely deleted - the odd one may be in use and cannot be deleted. Temember to empty the Recycle bin after deleting the files.
    Delete all files in C:\Windows|Temp with the same notes as above.
    Empty out your Temporary Internet Files - Tools > Internet Options - Browsing History - Delete button and check Temporary Internet files only.
    Back on Internet Options - Browsing History - Settings button and set the disk space to use to 50 Mb
    Reduce the disk space allocated to System Restore .....
    Right click My Computer icon > Properties > System Restore tab and set the slider to say 6% - default is 12%. You will lose some early Restore points, but doubt you would ever want to go back that far.
  10. 2008/11/26
    No cause for alarm :) - not malware associated, but still a puzzle to me.
  11. 2008/11/26
    surferdude2
    Pete, I was thinking that the folder named 1 was a user profile folder that has been created. That sounds reasonable based on its location. That's the basis for my suggestion of dumping the TEMP folder for that user profile.
  12. 2008/11/27
    Dude - you are no doubt right - my first reaction was that it was not kosher, thinking that most folks would give a user profile a name rather than a number :)
  13. 2008/11/27
    hawk22
    hawk22 Geek Member
    Hi Pete,
    I am not disputing your comments regarding moving My Documents, I have though used the function that MS provides in XP by right clicking on the "My Documents" Icon on the desktop Properties and Move and it will ask if you want to move all the files and folders with it to the new location. I have done this and moved not just to a different partition but another HD on the system.
    Maybe I am barking up the wrong tree in this situation.
    hawk22
  14. 2008/11/27
    hawk22
    My quote
    was lifted straight out of Tweak UI :)
  15. 2008/11/27
    Frank McLean
    surferdude2 PeteC Hawk22
    Hi Guys!
    I sincerely want to thank you for all of your help. Here's the update:
    Ran Disk Cleanup which found "Old Compressed Files" which I deleted.
    Ran defrag but defrag was still saying I only had 1.1 GB free and needed 1.5 Free to run defrag completely. I chose to run defrag anyway. It reported back that a number of items wern't defraged such as the Windows folder.
    surferdude2
    There wasn't any C:\Documents and Settings\1\Local Settings\Temp folder.
    I Used eCleaner which I had and assume it is similar to ATF-Cleaner or CCleaner to remove: Temporary Internet files, IE typed URLS, IE history, Recent Documents List and Windows Temp Files.
    Ran Start > Run > type in %temp% it found 43 folders or files I was able to delete 42 of them.
    In C:\Windows\Temp there were 13 folders or files and I was able to delete 12 of them.
    In Temporary Internet Files - Tools > Internet Options - Browsing History I deleted check Temporary Internet files, History and form data.
    I set Computer icon > Properties > System Restore tab slider to 6%
    Hawk22
    I don't have any My Documents folder on drive C but I do have a Frank McLean folder that may have originally been a My Docs folder that was renamed. But this folder is 0 bytes in size as I don't put anything in it.
    I tried to move folder 1 to drive D and a "Move" window poped up with the following message: "1 is a Windows system folder and is required to run properly. It cannot be moved or renamed." Perhaps this folder is unique to Windows XP Professional or the sysem folder might have just been named "1" but the person who installed windows.
    Thank you all again for you help, especially PeteC for taking the time to provide such very explicit instructions. The net result of all of the above is that it now indicates that I have 3.08 GB of free space on drive C.
    Peter I have downloaded the PDF file for Acronis Disk Director but haven't read it yet. Reading that and evaluating other partition programs as well is next on my todo list. Tonight I'm going to try to defrag again, now that I've got a little more free space. Then it's on to expanding the drive C partition. I will let you know how that progresses or works out.
    Thanks much,
    Frank
  16. 2008/11/28
    Yes, you have gained temporary relief, but I feel that it won't last long :)
    Sooner rather than later you will have to bite the bullet and expand the partition - my guess is that it will be painless :D
  17. 2008/11/28
    surferdude2
    You would still be well advised to run one of the tools I linked earlier or else clean your user profile/profiles temp folders manually. They likely are wasting lots of space. The eCleaner you ran does not touch them.
    Check in Control Panel under User Profiles to verify if the "1" is a listed profile. If so and you aren't using it, you can delete it while viewing profiles and dump the files within it when asked. I think you may be carrying along quite a bit of baggage in that profile based on what you posted earlier:
    You certainly don't need Application Data and Local Settings for a user that will never be logged on. ;)
  18. 2008/11/29
    gwiner7041 Lifetime Subscription
    gwiner7041 Inactive
    Hello I've deleted all my Temp files etc but still come up with only 2.60KB of free space on my C drive. I do have a empty D drive 80KG of free space. What in your opinion would be the best solution for myself to gain more C drive space so at least I could defrag again my C drive. I'm not what you call a expert by no means but I read alot.
    Please could someone inject there expertise on my issue. Step by step if you know what I mean. Thanks you very much.
    Garry
  19. 2008/11/29
    gwiner7041
    Not too happy about you hijacking this thread, but briefly ....
    Enlarge the partition using one of the pieces of software noted above. If you keep all your files in My Documents you will gain space on C\ by moving it to D:\ as detailed earlier in this thread.
