excel xp column headers
Discussion in 'Other PC Software' started by maxmangion, 2004/03/26.
  1. 2004/03/26
    maxmangion
    maxmangion Inactive Thread Starter
    when opening excel xp, the column headers are numbered 1, 2,3 ,4 etc rather than as the old 2000 style A, B, C, D etc.
    Is there a way to get the letter column heading format rather than the integers ?
  2. 2004/03/26
    This may be a feature of Excel XP - I run 2003 and can find no way of changing the column headers from letters to integers.
    Bound to be someone around the Board with a definitive answer on this.
    KevinSaul
    KevinSaul Inactive
    I'm running Excel XP and mine shows letters accross the top and numbers down the side, the same as always. I can't find any way of changing the default headers in the help files but if I get a little free time later I'll continue to research this.
  5. 2004/03/26
    Suggest you try a Repair of Excel
  6. 2004/03/29
    maxmangion
    thank you for your suggestions, but somehow i managed to solve the problem. Actually it is not a problem it is just a new feature in excel the "R1C1 reference style" which was turned on in the options. You can get to it by Tools->Options->General. By unticking it's option i got back the letters in the column headings.
    Thanks for your support!
  7. 2004/03/29
    Thanks for posting back with the solution - never really paid much attention to that check box!!
  8. 2004/03/29
    KevinSaul
    KevinSaul Inactive
    Glad you found it, learn something new every day!!!! :D
