Excel won't print in color
Discussion in 'Other PC Software' started by PhilArt, 2002/03/20.
  1. 2002/03/20
    PhilArt
    PhilArt Inactive Thread Starter
    Excel won't print in color even after specifying clearly on my HP t45. All else prints in color ok.
  2. 2002/03/20
    Rod
    Rod Well-Known Member
    Open Excel, click on the File menu, click Page Setup, and then click the Sheet tab. In the "Print" section of the Sheet tab remove any checkmarks from "Black & White ", and "Draft Copy ".
    Then click on the Options button, make sure "Color" is selected in your Printer Settings, click OK. You should be set.
    Hope this helps. :)
    Rod,
