Excel Problems
Discussion in 'Other PC Software' started by ASL, 2010/12/21.
  1. 2010/12/21
    ASL
    ASL Inactive Thread Starter
    I am using a very simple spreadsheet adding columns of numbers into a SUM. It had been working just fine but now when I make a change to one of the numbers in the column, the change is not reflected in my sum/total cell.
    At the end of the sheet I am adding several SUM/total cells to get one big total -- same thing is happening -- if, for example, I delete one of the numbers on the sheet, the change is not reflected in the total line.
    Can someone please help!
    Thanks,
    Anita
    ASL,
  2. 2010/12/22
    Welcome to WindowsBBS;)
    Does hitting the F5 (recalculate) key help?
