Excel 2010 Sum Function issue
Discussion in 'Other PC Software' started by SUPPO, 2010/12/12.
  1. 2010/12/12
    SUPPO
    SUPPO Inactive Thread Starter
    I am having some issues with the SUM function in Excel 2010.
    I am trying to SUM the following:
    F11: 500
    F12: 500
    F13: 37.22
    F14: -1037
    F15: -.22
    when i use the formula =F11+F12+F13+F14+F15 and when I use the formula =SUM(F11:F15) I get the following result: 0.0000000000000272837308301632000000000
    I have all cells formatted as a number. Anyone have any thoughts on what is going on here? would seem like pretty straight forward math. this random decimal error doesn't make any sense at all.
    any thoughts or insight would be appreciated.
  2. 2010/12/12
    BurrWalnut
    BurrWalnut Well-Known Member Alumni
    If you set all the fields to 2 decimal places, the result will be 0 (zero).
    wildfire
    wildfire Getting Old
    To expand on BurrWalnut's solution, it's impossible for a processor to store an exact float number (without exceedingly large overheads) and there will always be a margin of error. In your case do you really need results in excess of 13 decimal places?
