Resolved [Error running Falconview: 'encountered a problem and needs to close']
Discussion in 'Other PC Software' started by Mr Dit, 2012/01/07.
  1. 2012/01/07
    Mr Dit
    Mr Dit Inactive Thread Starter
    Probably a long shot, but I've loaded, removed, and reloaded Falconview four times now and it worked for a short time after the second removal/reload but now when I launch the program, I get the Popup reading 'FalconView application file has encountered a problem and needs to close. We are sorry for the inconvenience. I clicked on the Send Error Report, but this is doing me no good. I desperately need this program to do my job so any help would be a blessing.
  2. 2012/01/07
    SpywareDr
  5. 2012/01/07
    Mr Dit
    Thanks gents. Yes I've tediously gone through the FAQ without success. When I managed to get it to run on my 2nd try, I actually went into the registry and removed everything related to FVW.exe. I'll try Revo.
  6. 2012/01/07
    Mr Dit
    Used revo and deleted everything it found during post removal scan. Reinstalled (4.0.1) and still have the same problem. Pop-up failure as soon as I launch.
  7. 2012/01/07
    SpywareDr
  8. 2012/01/07
    What version of Windows are you using? Is the software compatible with it ?
  9. 2012/01/07
    Mr Dit
    XP Pro SP3. I've ran FV 3.0 for years on this laptop but it quit working. Loaded 4.0.1 after uninstall of 3.0 and it worked for a couple but after I edited the local point database using PFPS admin, it quit. No futher success with uninstall/install. I've read all relevant forum threads but no help. Guess I'll have to join and post there.
  10. 2012/01/07
    SpywareDr
  11. 2012/01/07
    Mr Dit
    First thing I wanted to try but my System Restore gives me a blank box where the calendar should be and I haven't been able to fix this. Just went through 2 days on the virus/malware section of this BBS so I'm sure my system is clean.
  12. 2012/01/07
    SpywareDr
    Yep. One step of cleaning up after an infection is to make sure you remove all Restore points, (so that the user can't inadvertently reinfect their computer).
  13. 2012/01/07
    Mr Dit
    Well, I can't even do that because I don't have a calendar in select restore point and I can't create one because when I try that, my cursor won't go into the restore point description box.
  14. 2012/01/07
    Mr Dit
    SysRestoreCalendar found and fixed two missing registry items. Still no System Restore calendar. Only a box where it should be. I've also tried everything on the Microsoft site.
  16. 2012/01/07
    Did you reboot - necessary for some registry changes.
  17. 2012/01/07
    Mr Dit
    Yep. Still a no go.
  18. 2012/01/07
    Mr Dit
    As I mentioned, I've exhausted all of the Microsoft kb recommended fixes. Including this one-all of the registry items listed in this kb item were already in accordance with MS recommended settings.
  20. 2012/01/07
    SpywareDr
