ERROR: couldnt load library OLEACC.dll
Discussion in 'Legacy Windows' started by jodysharkey, 2003/08/05.
  1. 2003/08/05
    jodysharkey
    jodysharkey Inactive Thread Starter
    Sorry guys but I didnt know where else to come...
    When I attempt to run KAZAA on my pc a little error window pops up and says "couldnt load library OLEACC.dll" - the kazaa files d/l alright to my pc and onto the desktop but they just wont run..
    is there anything i can do..please help!
  2. 2003/08/05
    MinnesotaMike
    MinnesotaMike Geek Member
    jodysharkey,
    Welcome to the board! Did you try reinstalling KAZAA to see if it helps?
    Mike
    Welshjim
    Welshjim Inactive
    OLEACC.dll is a MS file that comes with your installation of Windows98. Have you run a Find to see if you still have it on your PC? (it should be in C:\Windows\System)
    If not, try reinstalling from your Win98 CD or System File Checker.
    If you find it, you might try re-registering it. Start|Run|type regsvr32 oleacc.dll|OK. And it is possible that the oleacc.dll file you do have is corrupt, but let's save that for another post.
    Of course a special version of OLEACC.dll may come with Kazaa, in which case MinnesotaMike's suggestion is a good one.
