Embedding sound in email
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by rasrealtor, 2008/11/24.
  1. 2008/11/24
    rasrealtor
    rasrealtor Inactive Thread Starter
    A question was posed by some who would like to know how to embed a MIDI file in Thunderbird 2.0. If there is a way, can that sound be saved or "lifted" if not sent as an attachment? Any advice appreciated.
  2. 2008/12/02
    Ramona
    Ramona Geek Member Alumni
    Welcome to the Forum, rasrealtor!
    Thunderbird still does not support that feature.
    If you select: Insert | HTML you can embed a remote sound file on a web server.
    If you attach the file, select: File | Send Later then edit the message code in your Unsent folder file, then you can probably construct an embedded sound, and Thunderbird can send the modified message.
    Thunderbird 3 builds support plugins, so they can play some embedded sound files, but as far as I know they still cannot do the embedding.
    FWIW, very few folks like the embedded sound... ;)
