emailspypro
Discussion in 'Security and Privacy' started by noahdfear, 2003/06/01.
  1. 2003/06/01
    noahdfear
    noahdfear Inactive Thread Starter
    someone used a program called emailspypro to attach all my emails which can then be veiwed, then blocked or sent on. i dont know what else it will allow them to do but it has already created problems for me.since its hidden well, i dont know how or where to look for it to get it out.can anyone help? oh, in case anybody is curious, it was my ex-wife that did it.
  2. 2003/06/01
    mr.mark
    mr.mark Inactive
    i see it is shareware. perhaps you can install it yourself, then use the uninstall feature, to get it off your computer.
    or try emailing the company to ask how to uninstall.
    or look in your list of start up processes in hopes of finding it there and preventing it from starting.
    you could also run a tool like regcleaner and try to delete the registry entries for it
    just some ideas...
    good luck
    mr.mark
    mr.mark Inactive
    TrojanHunter developer listens...
    check this out
    Ruleset update: 35x-2003-06-04
    35x-2003-06-04
    - Added Delsha.100
    - Added BeastDoor.209
    - Added HttpRat.017
    - Added Lerk.100
    - Added EmailSpyPro.431
