ELSE Problem in batchfile
Discussion in 'Other PC Software' started by edmund085, 2009/04/24.
  1. 2009/04/24
    edmund085
    edmund085 Inactive Thread Starter
    Help!
    I have a problem about the Else statement in the batch file.
    :variables
    IF exist C:\program1\_OOLEMUP.MSF rename C:\program1\_OOLEMUP.MSF fedx.exe
    IF not exist C:\program1\_OOLEMUP.MSF rename C:\program1\mawee.exe wowe.exe
    IF exist C:\program1\wowe.exe (ECHO File wowe.exe exist) ELSE (start notepad.exe)
    If defined C:\program1\cow.exe GOTO makelist
    If not defined C:\hexmixer.doc copy wowe.exe C:\program2
    GOTO MENU
    the problem is that the else statement doesnt even the file wowe.exe is esisted. The command 2 doesnt execute but the first command execute. Pls help. And also, how do type If defined statements, because it wont work either, and i dont understand it's use.:(
  2. 2009/04/24
    wildfire
    wildfire Getting Old
    Hi Edmund and welcome to windows bbs :D
    A good starting point would be what windows version you are using?
    There are several errors in your batch file but if you answer the above I'll post a correct version and where you went wrong ;)
    edmund085
    i'm using windows xp service pack 2. And does the batch file commands is different from other versions?
  5. 2009/04/25
    Yes, XP does not contain DOS and has its own set of commands. Some are familiar and some are new.
    Go to Start > Help & Support > search Help for "Command line reference A-Z" (without the quotes).
  6. 2009/04/26
    wildfire
    Hi Edmund,
    Did Tony's post help you or would you like further assistance?
    Please accept my apologies but sometimes real life is a pain in the backside ;)
