ECS Pentium Pro P6FX1-A MotherBoard.
Discussion in 'PC Hardware' started by BreezyCricket, 2003/09/12.
  1. 2003/09/12
    BreezyCricket Lifetime Subscription
    BreezyCricket Well-Known Member Thread Starter
    I am trying to get the above MotherBoard to work and am not having much luck because the manual does not show where each of the various power leads connect.
    I have a Power SW (White & Yellow Wire), Reset SW (White & Blue), HDD LED (White & Red), Power LED (White & Green) & Speaker (Red & Black)
    If anyone could assist, preferably with a diagram, to my e-mail address, I would be eternally grateful.
    callisto@telus.net
    Many Thanks.
  2. 2003/09/12
    giles
    giles Inactive
    Hi BreezyCricket.
    Check here.
    http://www.ecs.com.tw/download/manual_p6b.htm
    Find the motherboard in the left column and download the zip file in the right column. Unzip it and you'll find the manual in Acrobat and the bios in a .DOC file. I think the stuff you're looking for is in Ch3.pdf.
    It's a manual for that motherboard. That is an old board and the plugs are not all clustered in one neat place. You'll find most everything in the manual. Some things might not be on there to match the case wires tho. Good luck.
    Giles
    Many Thanks for the assistance.
    I finally solved my problem, with the help of my Grandson and his younger cousin. I am told they will even be smarter when they start school. :)
