E-mail problem
Discussion in 'Internet Explorer & Microsoft Edge' started by Choochoo, 2003/02/15.
  1. 2003/02/15
    Choochoo
    Choochoo Inactive Thread Starter
    Several pierce of e-mail have arrived from one source. They have attachments which I am unable to open. I receive a message that "OE has removed the ability to open" these unsafe attachments.
    What is "OE" and how do I determine if these truly are unsafe?
  2. 2003/02/15
    Daizy
    Daizy Inactive
    Hi Choochoo
    OE is outlook Express. It's set itself to delete any potentially harmful attachments for you. So that you can choose for yourself, Open outlook Express.......... go to tools........then options...then your security tab. Take the tick out of, " Do not allow attachments to be saved or opened..........." Click apply...then ok.
    Daizy
    Choochoo
    Thank you, I too depend on coffee as a source of "Experience" I must need to drink MUCH more
  5. 2003/02/15
    aleekat
    aleekat Inactive
    "and how do I determine if these truly are unsafe? "
    A good anitvirus program and kept up to date!!!
  6. 2003/02/15
    Daizy
    Daizy Inactive
    Oops Aleekat....thanks for that catch. I missed the second part of the question.
    Choochoo? What AV are you running? And are you up to date?
    Daizy
  7. 2003/02/23
    gene
    gene Inactive
    E-mail problem Can't open attachments
    Daizy's advice was right one. It worked just fine.:D
    gene,
    #6
  8. 2003/02/23
    Daizy
    Daizy Inactive
    :confused: gene/ Choochoo :confused:
    (Are you one and the same?)
    So happy to hear you got it sorted. Thanks so much for taking the time to post back!
    Daizy
  9. 2003/02/25
    Choochoo
    Sorry Daizy, I am not gene, but you are welcome
