DVD Recorder not installed correctly
Discussion in 'Windows XP' started by monkeymike30, 2009/09/05.
  1. 2009/09/05
    monkeymike30
    monkeymike30 Inactive Thread Starter
    Hi Can any one help
    My Disc drive is not installed correctly. When I right click properties over D drive, I do not get the option tab Record.
    So when I go in to into Media player it request I connect a buner.
    I have Nero and Roxio installed
    I have uninstalled the disc drive and restarted and it find again but not with the recorder tab, so I think that window is not reconizing this Pioneer DVD-rw 212 as a recordable drive ?
    How can I correct this Problem?
  2. 2009/09/05
    Welcome to WindowsBBS :)
    Try the solution offered here ....
    http://forums.support.roxio.com/index.php?showtopic=40028
    or here ....
    http://www.tomshardware.co.uk/forum/page-148394_35_0.html
    and maybe here ....
    http://forums.techguy.org/multimedia/500052-solved-recording-tab-missing-device.html
    I think your problem arises through having Roxio and Nero installed - Roxio is referenced in the threads above. I would get rid of one - Roxio would be my choice to dump. That may be sufficient to resolve your problem.
