DVD player wont read DVD
Discussion in 'PC Hardware' started by slk230mb, 2002/11/22.
  1. 2002/11/22
    slk230mb
    slk230mb Inactive Thread Starter
    I am trying to play a DVD on my computer and it wont read the disc. In My Computer the icon for my DVD player doesnt change, and even launching the DVD Player has no effect. Any suggestions will be appreciated.
    --Steve
  2. 2002/11/24
    dale442
    dale442 Inactive
    Is this a new DVD player or is this a problem that just popped up? Also, what OS are you using?
    Dale
    slk230mb
    Its not a new DVD player and i am running win98SE. I'm pretty sure its the DVD not the computer though.
  5. 2002/11/25
    Sal_gal
    Sal_gal Inactive
    More questions
    DVD Won't Play:
    Was the DVD playing previously? WEre you viewing movies or playing music?
    I had a similar problem. The light was on, the tray opened but nothing happened. I had the cables connected incorrectly.
    I think you need to give out more information. Exactly what happens? Does the light go on? Does the tray open & eject?
