DUMP DATA - BSOD Problem
Discussion in 'Windows XP' started by zombie, 2006/04/21.
  1. 2006/04/21
    zombie
    zombie Inactive Thread Starter
    To make a long story short, I had heavy problems with my system BSODing all the time. Figured out it was a driver problem, but couldn't get further because the system didn't write any dumps. Rebuilt the system, made a custom WInXP CD with the latest nvraid drivers integrated (i thought this could be the cause of my problem). Now the system is already a lot more stable. Since the rebuild I've had 2 BSODs, the dump data of both can be found below. Today when I switched the PC on and logged in I did not get BSOD but the same two errors came up as "Your system has recovered from serious error" (by the same two errors I mean the same bugcheck codes). Anyway, the system is pretty stable as is, but I'd obviously like to get rid of this problem completely. I'm sure someone can point me in the right direction with the data below:
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.6.0003.5
    Loading Dump File [C:\WINDOWS\Minidump\Mini042006-01.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 2600.xpsp_sp2_rtm.040803-2158
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
    Debug session time: Wed Apr 19 21:23:22.656 2006 (GMT+2)
    System Uptime: 0 days 0:35:55.218
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 1000007F, {d, 0, 0, 0}
    Probably caused by : Pool_Corruption ( nt!ExDeferredFreePool+fd )
    Followup: Pool_corruption
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    UNEXPECTED_KERNEL_MODE_TRAP_M (1000007f)
    This means a trap occurred in kernel mode, and it's a trap of a kind
    that the kernel isn't allowed to have/catch (bound trap) or that
    is always instant death (double fault). The first number in the
    bugcheck params is the number of the trap (8 = double fault, etc)
    Consult an Intel x86 family manual to learn more about what these
    traps are. Here is a *portion* of those codes:
    If kv shows a taskGate
    use .tss on the part before the colon, then kv.
    Else if kv shows a trapframe
    use .trap on that value
    Else
    .trap on the appropriate frame will show where the trap was taken
    (on x86, this will be the ebp that goes with the procedure KiTrap)
    Endif
    kb will then show the corrected stack.
    Arguments:
    Arg1: 0000000d, EXCEPTION_GP_FAULT
    Arg2: 00000000
    Arg3: 00000000
    Arg4: 00000000
    Debugging Details:
    BUGCHECK_STR: 0x7f_d
    CUSTOMER_CRASH_COUNT: 1
    LAST_CONTROL_TRANSFER: from 80543e6f to 80543803
    IRP_ADDRESS: 88326008
    STACK_TEXT:
    b3a9bbc8 80543e6f 880cd008 8835cc50 880ce018 nt!ExDeferredFreePool+0xfd
    b3a9bc08 804f388c 880ce008 882c6088 88326048 nt!ExFreePoolWithTag+0x489
    b3a9bc5c 804fcfbf 88326048 b3a9bca8 b3a9bc9c nt!IopCompleteRequest+0xf4
    b3a9bcac 80500198 00000000 00000000 00000000 nt!KiDeliverApc+0xb3
    b3a9bcc4 804f99be 00000000 b3a9bd1c 00000000 nt!KiSwapThread+0x64
    b3a9bcec 805b4a78 00000001 00000006 b3a9bd01 nt!KeWaitForSingleObject+0x1c2
    b3a9bd50 8053c808 000000ec 00000001 b3a9bd1c nt!NtWaitForSingleObject+0x9a
    b3a9bd50 7c90eb94 000000ec 00000001 b3a9bd1c nt!KiFastCallEntry+0xf8
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    05ed977c 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    80543803 8913 mov [ebx],edx
    SYMBOL_STACK_INDEX: 0
    FOLLOWUP_NAME: Pool_corruption
    SYMBOL_NAME: nt!ExDeferredFreePool+fd
    MODULE_NAME: Pool_Corruption
    IMAGE_NAME: Pool_Corruption
    DEBUG_FLR_IMAGE_TIMESTAMP: 0
    FAILURE_BUCKET_ID: 0x7f_d_nt!ExDeferredFreePool+fd
    eax=8814e538 ebx=ffffffff ecx=8814e538 edx=881df008 esi=8055a6c0 edi=000001ff
    eip=80543803 esp=b3a9bb88 ebp=b3a9bbc8 iopl=0 nv up ei ng nz ac po cy
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010297
    nt!ExDeferredFreePool+0xfd:
    80543803 8913 mov [ebx],edx ds:0023:ffffffff=????????
    b3a9bbc8 80543e6f 880cd008 8835cc50 880ce018 nt!ExDeferredFreePool+0xfd (FPO: [Non-Fpo])
    b3a9bc08 804f388c 880ce008 882c6088 88326048 nt!ExFreePoolWithTag+0x489 (FPO: [Non-Fpo])
    b3a9bc5c 804fcfbf 88326048 b3a9bca8 b3a9bc9c nt!IopCompleteRequest+0xf4 (FPO: [Non-Fpo])
    b3a9bcac 80500198 00000000 00000000 00000000 nt!KiDeliverApc+0xb3 (FPO: [Non-Fpo])
    b3a9bcc4 804f99be 00000000 b3a9bd1c 00000000 nt!KiSwapThread+0x64 (FPO: [0,0,0])
    b3a9bcec 805b4a78 00000001 00000006 b3a9bd01 nt!KeWaitForSingleObject+0x1c2 (FPO: [Non-Fpo])
    b3a9bd50 8053c808 000000ec 00000001 b3a9bd1c nt!NtWaitForSingleObject+0x9a (FPO: [Non-Fpo])
    b3a9bd50 7c90eb94 000000ec 00000001 b3a9bd1c nt!KiFastCallEntry+0xf8 (FPO: [0,0] TrapFrame @ b3a9bd64)
    start end module name
    804d7000 806cd280 nt ntkrnlpa.exe Wed Aug 04 07:58:36 2004 (41107B0C)
    806ce000 806ee380 hal halaacpi.dll Wed Aug 04 07:59:05 2004 (41107B29)
    b3b70000 b3bb0380 HTTP HTTP.sys Wed Aug 04 08:00:09 2004 (41107B69)
    b4241000 b4293180 srv srv.sys Wed Aug 04 08:14:44 2004 (41107ED4)
    b453c000 b4568400 mrxdav mrxdav.sys Wed Aug 04 08:00:49 2004 (41107B91)
    b467e000 b4692400 wdmaud wdmaud.sys Wed Aug 04 08:15:03 2004 (41107EE7)
    b583b000 b5849d80 sysaudio sysaudio.sys Wed Aug 04 08:15:54 2004 (41107F1A)
    b5937000 b593a280 ndisuio ndisuio.sys Wed Aug 04 08:03:10 2004 (41107C1E)
    b629c000 b62aed00 dump_nvraid dump_nvraid.sys Fri Aug 19 02:52:07 2005 (43052D37)
    b62d7000 b62e8080 LMouKE LMouKE.Sys Wed Mar 29 02:55:57 2006 (4429DB1D)
    b62e9000 b63a36e0 avg7core avg7core.sys Tue Feb 21 09:57:50 2006 (43FAC7FE)
    b63a4000 b6412380 mrxsmb mrxsmb.sys Wed Aug 04 08:15:14 2004 (41107EF2)
    b6413000 b643e180 rdbss rdbss.sys Wed Aug 04 08:20:05 2004 (41108015)
    b643f000 b6460d00 afd afd.sys Wed Aug 04 08:14:13 2004 (41107EB5)
    b6461000 b6488c00 netbt netbt.sys Wed Aug 04 08:14:36 2004 (41107ECC)
    b64b1000 b64d1f00 ipnat ipnat.sys Wed Aug 04 08:04:48 2004 (41107C80)
    b6553000 b656b700 NVTcp NVTcp.sys Sat Oct 15 21:54:36 2005 (43515E7C)
    b656c000 b65c3a80 tcpip tcpip.sys Wed Aug 04 08:14:39 2004 (41107ECF)
    b65c4000 b65d6400 ipsec ipsec.sys Wed Aug 04 08:14:27 2004 (41107EC3)
    b8742000 b8745a00 kbdhid kbdhid.sys Wed Aug 04 07:58:33 2004 (41107B09)
    b8752000 b8754f80 mouhid mouhid.sys Fri Aug 17 22:47:57 2001 (3B7D82FD)
    b875e000 b8760900 Dxapi Dxapi.sys Fri Aug 17 22:53:19 2001 (3B7D843F)
    b877a000 b878a480 nvarm nvarm.sys Wed Apr 13 21:34:21 2005 (425D743D)
    b878b000 b8870000 nvmcp nvmcp.sys Wed Apr 13 21:34:21 2005 (425D743D)
    b8870000 b8893980 portcls portcls.sys Wed Aug 04 08:15:47 2004 (41107F13)
    b8894000 b88f9300 nvapu nvapu.sys Wed Apr 13 21:34:01 2005 (425D7429)
    b8927000 b895a200 update update.sys Wed Aug 04 07:58:32 2004 (41107B08)
    b895b000 b898b100 rdpdr rdpdr.sys Wed Aug 04 08:01:10 2004 (41107BA6)
    b898c000 b899ce00 psched psched.sys Wed Aug 04 08:04:16 2004 (41107C60)
    b899d000 b89b3680 ndiswan ndiswan.sys Wed Aug 04 08:14:30 2004 (41107EC6)
    b89b4000 b89c7900 parport parport.sys Wed Aug 04 07:59:04 2004 (41107B28)
    b89c8000 b89db780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 08:07:04 2004 (41107D08)
    b89dc000 b8d57340 nv4_mini nv4_mini.sys Fri Mar 10 02:40:42 2006 (4410CB0A)
    b8d58000 b8d8ad80 NVSNPU NVSNPU.SYS Wed Apr 06 12:22:01 2005 (4253B849)
    b8d8b000 b8dcaf00 NVNRM NVNRM.SYS Wed Apr 06 12:22:11 2005 (4253B853)
    b9544000 b9552b80 drmk drmk.sys Wed Aug 04 08:07:54 2004 (41107D3A)
    b9554000 b955d480 NDProxy NDProxy.SYS Fri Aug 17 22:55:30 2001 (3B7D84C2)
    b9564000 b9572100 usbhub usbhub.sys Wed Aug 04 08:08:40 2004 (41107D68)
    b9574000 b957df00 termdd termdd.sys Wed Aug 04 07:58:52 2004 (41107B1C)
    b9584000 b958c900 msgpc msgpc.sys Wed Aug 04 08:04:11 2004 (41107C5B)
    b9594000 b959fd00 raspptp raspptp.sys Wed Aug 04 08:14:26 2004 (41107EC2)
    b95a4000 b95ae200 raspppoe raspppoe.sys Wed Aug 04 08:05:06 2004 (41107C92)
    b95b4000 b95c0880 rasl2tp rasl2tp.sys Wed Aug 04 08:14:21 2004 (41107EBD)
    b95c4000 b95d3d80 serial serial.sys Wed Aug 04 08:15:51 2004 (41107F17)
    ba1cd000 ba1d0c80 mssmbios mssmbios.sys Wed Aug 04 08:07:47 2004 (41107D33)
    ba468000 ba474200 dump_CLASSPNP dump_CLASSPNP.SYS Wed Aug 04 08:14:26 2004 (41107EC2)
    ba4a8000 ba4b0d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 08:08:18 2004 (41107D52)
    ba512000 ba534680 ks ks.sys Wed Aug 04 08:15:20 2004 (41107EF8)
    ba56d000 ba58fe80 USBPORT USBPORT.SYS Wed Aug 04 08:08:34 2004 (41107D62)
    ba5ac000 ba5ae280 rasacd rasacd.sys Fri Aug 17 22:55:39 2001 (3B7D84CB)
    ba5ee000 ba608580 Mup Mup.sys Wed Aug 04 08:15:20 2004 (41107EF8)
    ba609000 ba635a80 NDIS NDIS.sys Wed Aug 04 08:14:27 2004 (41107EC3)
    ba636000 ba6c2480 Ntfs Ntfs.sys Wed Aug 04 08:15:06 2004 (41107EEA)
    ba6c3000 ba6d9780 KSecDD KSecDD.sys Wed Aug 04 07:59:45 2004 (41107B51)
    ba6da000 ba6f8780 fltMgr fltMgr.sys Wed Aug 04 08:01:17 2004 (41107BAD)
    ba6f9000 ba70fd80 nvatabus nvatabus.sys Fri Aug 19 02:52:05 2005 (43052D35)
    ba710000 ba722d00 nvraid nvraid.sys Fri Aug 19 02:52:07 2005 (43052D37)
    ba723000 ba748700 dmio dmio.sys Wed Aug 04 08:07:13 2004 (41107D11)
    ba749000 ba767880 ftdisk ftdisk.sys Fri Aug 17 22:52:41 2001 (3B7D8419)
    ba768000 ba778a80 pci pci.sys Wed Aug 04 08:07:45 2004 (41107D31)
    ba779000 ba7a6d80 ACPI ACPI.sys Wed Aug 04 08:07:35 2004 (41107D27)
    ba8a8000 ba8b0c00 isapnp isapnp.sys Fri Aug 17 22:58:01 2001 (3B7D8559)
    ba8b8000 ba8c6e80 ohci1394 ohci1394.sys Wed Aug 04 08:10:05 2004 (41107DBD)
    ba8c8000 ba8d5000 1394BUS 1394BUS.SYS Wed Aug 04 08:10:03 2004 (41107DBB)
    ba8d8000 ba8e2500 MountMgr MountMgr.sys Wed Aug 04 07:58:29 2004 (41107B05)
    ba8e8000 ba8f4200 CLASSPNP CLASSPNP.SYS Wed Aug 04 08:14:26 2004 (41107EC2)
    ba8f8000 ba904c80 VolSnap VolSnap.sys Wed Aug 04 08:00:14 2004 (41107B6E)
    ba908000 ba910e00 disk disk.sys Wed Aug 04 07:59:53 2004 (41107B59)
    ba968000 ba970300 NVENETFD NVENETFD.sys Wed Apr 06 12:22:26 2005 (4253B862)
    ba998000 ba9a7180 nic1394 nic1394.sys Wed Aug 04 07:58:28 2004 (41107B04)
    ba9b8000 ba9c0700 wanarp wanarp.sys Wed Aug 04 08:04:57 2004 (41107C89)
    ba9c8000 ba9d6d80 arp1394 arp1394.sys Wed Aug 04 07:58:28 2004 (41107B04)
    ba9d8000 ba9e0700 netbios netbios.sys Wed Aug 04 08:03:19 2004 (41107C27)
    ba9e8000 ba9f0880 Fips Fips.SYS Sat Aug 18 03:31:49 2001 (3B7DC585)
    baa38000 baa47900 Cdfs Cdfs.SYS Wed Aug 04 08:14:09 2004 (41107EB1)
    baaa8000 baab0f80 LHidUsbK LHidUsbK.Sys Wed Mar 29 02:55:19 2006 (4429DAF7)
    baac8000 baad0a00 processr processr.sys Wed Aug 04 07:59:14 2004 (41107B32)
    baae8000 baaf5080 nvax nvax.sys Wed Apr 13 21:32:41 2005 (425D73D9)
    baaf8000 bab02380 imapi imapi.sys Wed Aug 04 08:00:12 2004 (41107B6C)
    bab08000 bab14180 cdrom cdrom.sys Wed Aug 04 07:59:52 2004 (41107B58)
    bab18000 bab26080 redbook redbook.sys Wed Aug 04 07:59:34 2004 (41107B46)
    bab28000 bab2c900 PartMgr PartMgr.sys Sat Aug 18 03:32:23 2001 (3B7DC5A7)
    bab58000 bab5ca80 Msfs Msfs.SYS Wed Aug 04 08:00:37 2004 (41107B85)
    bab60000 bab67880 Npfs Npfs.SYS Wed Aug 04 08:00:38 2004 (41107B86)
    bab70000 bab76980 LHidKE LHidKE.Sys Wed Mar 29 02:56:06 2006 (4429DB26)
    babc0000 babc4500 watchdog watchdog.sys Wed Aug 04 08:07:32 2004 (41107D24)
    babd0000 babd7b80 usbccgp usbccgp.sys Wed Aug 04 08:08:45 2004 (41107D6D)
    bac08000 bac09000 fdc fdc.sys unavailable (00000000)
    bac10000 bac14880 TDI TDI.SYS Wed Aug 04 08:07:47 2004 (41107D33)
    bac18000 bac1c580 ptilink ptilink.sys Fri Aug 17 22:49:53 2001 (3B7D8371)
    bac28000 bac2c080 raspti raspti.sys Fri Aug 17 22:55:32 2001 (3B7D84C4)
    bac30000 bac36000 kbdclass kbdclass.sys Wed Aug 04 07:58:32 2004 (41107B08)
    bac38000 bac3da00 mouclass mouclass.sys Wed Aug 04 07:58:32 2004 (41107B08)
    bac80000 bac86f00 avg7rsxp avg7rsxp.sys Thu Feb 23 01:39:36 2006 (43FCF638)
    bac88000 bac8c280 usbohci usbohci.sys Wed Aug 04 08:08:34 2004 (41107D62)
    bac90000 bac96800 usbehci usbehci.sys Wed Aug 04 08:08:34 2004 (41107D62)
    baca8000 bacae180 HIDPARSE HIDPARSE.SYS Wed Aug 04 08:08:15 2004 (41107D4F)
    bacb0000 bacb5200 vga vga.sys Wed Aug 04 08:07:06 2004 (41107D0A)
    bacb8000 bacbb000 BOOTVID BOOTVID.dll Fri Aug 17 22:49:09 2001 (3B7D8345)
    bad4c000 bad4fc80 serenum serenum.sys Wed Aug 04 07:59:06 2004 (41107B2A)
    bad50000 bad52580 ndistapi ndistapi.sys Fri Aug 17 22:55:29 2001 (3B7D84C1)
    bad64000 bad66580 hidusb hidusb.sys Fri Aug 17 23:02:16 2001 (3B7D8658)
    bad8c000 bad8ef00 ws2ifsl ws2ifsl.sys Fri Aug 17 22:55:58 2001 (3B7D84DE)
    bad94000 bad97280 nvnetbus nvnetbus.sys Wed Apr 06 12:22:28 2005 (4253B864)
    bada8000 bada9b80 kdcom kdcom.dll Fri Aug 17 22:49:10 2001 (3B7D8346)
    badaa000 badab100 WMILIB WMILIB.SYS Fri Aug 17 23:07:23 2001 (3B7D878B)
    badac000 badad700 dmload dmload.sys Fri Aug 17 22:58:15 2001 (3B7D8567)
    badba000 badbbf00 Fs_Rec Fs_Rec.SYS Fri Aug 17 22:49:37 2001 (3B7D8361)
    badcc000 badcda80 ParVdm ParVdm.SYS Fri Aug 17 22:49:49 2001 (3B7D836D)
    badd4000 badd5360 avgtdi avgtdi.sys Thu Aug 25 11:59:58 2005 (430D969E)
    baddc000 baddd080 Beep Beep.SYS Fri Aug 17 22:47:33 2001 (3B7D82E5)
    bade4000 bade5080 avg7rsw avg7rsw.sys Tue Jul 26 14:10:51 2005 (42E6284B)
    badf4000 badf5080 RDPCDD RDPCDD.sys Fri Aug 17 22:46:56 2001 (3B7D82C0)
    bae56000 bae57100 swenum swenum.sys Wed Aug 04 07:58:41 2004 (41107B11)
    bae58000 bae59280 USBD USBD.SYS Fri Aug 17 23:02:58 2001 (3B7D8682)
    bae81000 bae81d00 dxgthk dxgthk.sys Fri Aug 17 22:53:12 2001 (3B7D8438)
    baedc000 baedcc00 audstub audstub.sys Fri Aug 17 22:59:40 2001 (3B7D85BC)
    baf4f000 baf4fb80 Null Null.SYS Fri Aug 17 22:47:39 2001 (3B7D82EB)
    bf800000 bf9c0380 win32k win32k.sys Wed Aug 04 08:17:30 2004 (41107F7A)
    bf9c1000 bf9d2580 dxg dxg.sys Wed Aug 04 08:00:51 2004 (41107B93)
    bf9d3000 bfd9be00 nv4_disp nv4_disp.dll Fri Mar 10 02:31:16 2006 (4410C8D4)
    Unloaded modules:
    b4591000 b45bb000 kmixer.sys
    Checksum: 00000000
    b8dcb000 b8dcc000 drmkaud.sys
    Checksum: 00000000
    baa68000 baa75000 DMusic.sys
    Checksum: 00000000
    b465b000 b467e000 aec.sys
    Checksum: 00000000
    b4ebb000 b4ec9000 swmidi.sys
    Checksum: 00000000
    bae6e000 bae70000 splitter.sys
    Checksum: 00000000
    ba5b0000 ba5b4000 kbdhid.sys
    Checksum: 00000000
    ba9a8000 ba9b5000 i8042prt.SYS
    Checksum: 00000000
    bac20000 bac25000 Cdaudio.SYS
    Checksum: 00000000
    ba5b4000 ba5b7000 Sfloppy.SYS
    Checksum: 00000000
    babf8000 babfd000 Flpydisk.SYS
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
    Thanks!
  2. 2006/04/21
    zombie
    And here the second dump:
    Loading Dump File [C:\WINDOWS\Minidump\Mini042006-02.dmp]
    Built by: 2600.xpsp_sp2_gdr.050301-1519
    Debug session time: Thu Apr 20 02:01:13.140 2006 (GMT+2)
    System Uptime: 0 days 0:36:40.709
    BugCheck C2, {7, cd4, 0, 882ed008}
    GetUlongFromAddress: unable to read from 8055b6f0
    *** ERROR: Module load completed but symbols could not be loaded for dump_nvraid.sys
    *** ERROR: Module load completed but symbols could not be loaded for LMouKE.Sys
    *** ERROR: Module load completed but symbols could not be loaded for avg7core.sys
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for NVTcp.sys -
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for nvarm.sys -
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for nvmcp.sys -
    *** ERROR: Module load completed but symbols could not be loaded for nvapu.sys
    *** ERROR: Module load completed but symbols could not be loaded for nv4_mini.sys
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for NVSNPU.SYS -
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for NVNRM.SYS -
    *** ERROR: Module load completed but symbols could not be loaded for LHidUsbK.Sys
    *** ERROR: Module load completed but symbols could not be loaded for NVENETFD.sys
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for drmk.sys -
    *** ERROR: Module load completed but symbols could not be loaded for nvatabus.sys
    *** ERROR: Module load completed but symbols could not be loaded for nvraid.sys
    *** ERROR: Module load completed but symbols could not be loaded for AmdK8.sys
    *** ERROR: Module load completed but symbols could not be loaded for nvax.sys
    *** ERROR: Module load completed but symbols could not be loaded for avg7rsxp.sys
    *** WARNING: Unable to verify timestamp for fdc.sys
    *** ERROR: Module load completed but symbols could not be loaded for fdc.sys
    *** ERROR: Module load completed but symbols could not be loaded for LHidKE.Sys
    *** ERROR: Module load completed but symbols could not be loaded for nvnetbus.sys
    *** ERROR: Module load completed but symbols could not be loaded for avgtdi.sys
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for avg7rsw.sys -
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for nv4_disp.dll -
    Probably caused by : ntkrnlpa.exe ( nt!ExFreePoolWithTag+2a0 )
    Followup: MachineOwner
    BAD_POOL_CALLER (c2)
    The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.
    Arguments:
    Arg1: 00000007, Attempt to free pool which was already freed
    Arg2: 00000cd4, (reserved)
    Arg3: 00000000, Memory contents of the pool block
    Arg4: 882ed008, Address of the block of pool being deallocated
    Debugging Details:
    POOL_ADDRESS: 882ed008
    BUGCHECK_STR: 0xc2_7
    CUSTOMER_CRASH_COUNT: 2
    LAST_CONTROL_TRANSFER: from 80543c86 to 804f8925
    IRP_ADDRESS: 886d2db8
    STACK_TEXT:
    b3b66bb8 80543c86 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b
    b3b66c08 804f388c 882ed008 00000000 886d2df8 nt!ExFreePoolWithTag+0x2a0
    b3b66c5c 804fcfbf 886d2df8 b3b66ca8 b3b66c9c nt!IopCompleteRequest+0xf4
    b3b66cac 80500198 00000000 00000000 00000000 nt!KiDeliverApc+0xb3
    b3b66cc4 804f99be 00000000 b3b66d1c 00000000 nt!KiSwapThread+0x64
    b3b66cec 805b4a5c 00000001 00000006 b3b66d01 nt!KeWaitForSingleObject+0x1c2
    b3b66d50 8053c808 00000720 00000001 b3b66d1c nt!NtWaitForSingleObject+0x9a
    b3b66d50 7c90eb94 00000720 00000001 b3b66d1c nt!KiFastCallEntry+0xf8
    061c977c 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    80543c86 8b45f8 mov eax,[ebp-0x8]
    SYMBOL_STACK_INDEX: 1
    FOLLOWUP_NAME: MachineOwner
    SYMBOL_NAME: nt!ExFreePoolWithTag+2a0
    MODULE_NAME: nt
    IMAGE_NAME: ntkrnlpa.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 42250a1d
    FAILURE_BUCKET_ID: 0xc2_7_nt!ExFreePoolWithTag+2a0
    eax=ffdff13c ebx=00000cd4 ecx=00000000 edx=00000001 esi=882ed000 edi=88536ae0
    eip=804f8925 esp=b3b66ba0 ebp=b3b66bb8 iopl=0 nv up ei ng nz na po nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
    nt!KeBugCheckEx+0x1b:
    804f8925 5d pop ebp
    b3b66bb8 80543c86 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b (FPO: [Non-Fpo])
    b3b66c08 804f388c 882ed008 00000000 886d2df8 nt!ExFreePoolWithTag+0x2a0 (FPO: [Non-Fpo])
    b3b66c5c 804fcfbf 886d2df8 b3b66ca8 b3b66c9c nt!IopCompleteRequest+0xf4 (FPO: [Non-Fpo])
    b3b66cac 80500198 00000000 00000000 00000000 nt!KiDeliverApc+0xb3 (FPO: [Non-Fpo])
    b3b66cc4 804f99be 00000000 b3b66d1c 00000000 nt!KiSwapThread+0x64 (FPO: [0,0,0])
    b3b66cec 805b4a5c 00000001 00000006 b3b66d01 nt!KeWaitForSingleObject+0x1c2 (FPO: [Non-Fpo])
    b3b66d50 8053c808 00000720 00000001 b3b66d1c nt!NtWaitForSingleObject+0x9a (FPO: [Non-Fpo])
    b3b66d50 7c90eb94 00000720 00000001 b3b66d1c nt!KiFastCallEntry+0xf8 (FPO: [0,0] TrapFrame @ b3b66d64)
    804d7000 806cd280 nt ntkrnlpa.exe Wed Mar 02 02:34:37 2005 (42250A1D)
    b3b12000 b3b52100 HTTP HTTP.sys Sat Oct 09 01:48:20 2004 (41672744)
    b4283000 b42d4300 srv srv.sys Tue May 10 02:17:49 2005 (427FFDAD)
    b43ed000 b4419400 mrxdav mrxdav.sys Wed Aug 04 08:00:49 2004 (41107B91)
    b45f7000 b460b400 wdmaud wdmaud.sys Wed Aug 04 08:15:03 2004 (41107EE7)
    b6293000 b62a5d00 dump_nvraid dump_nvraid.sys Fri Aug 19 02:52:07 2005 (43052D37)
    b62a6000 b62a9280 ndisuio ndisuio.sys Wed Aug 04 08:03:10 2004 (41107C1E)
    b62ca000 b62cc900 Dxapi Dxapi.sys Fri Aug 17 22:53:19 2001 (3B7D843F)
    b62ce000 b62df080 LMouKE LMouKE.Sys Wed Mar 29 02:55:57 2006 (4429DB1D)
    b62e0000 b639a6e0 avg7core avg7core.sys Tue Feb 21 09:57:50 2006 (43FAC7FE)
    b639b000 b6409400 mrxsmb mrxsmb.sys Wed Jan 19 06:26:50 2005 (41EDE18A)
    b640a000 b6434a00 rdbss rdbss.sys Thu Oct 28 03:13:57 2004 (418047D5)
    b6435000 b6456d00 afd afd.sys Wed Aug 04 08:14:13 2004 (41107EB5)
    b6457000 b647ec00 netbt netbt.sys Wed Aug 04 08:14:36 2004 (41107ECC)
    b647f000 b649ff00 ipnat ipnat.sys Thu Sep 30 00:28:36 2004 (415B3714)
    b6521000 b6539700 NVTcp NVTcp.sys Sat Oct 15 21:54:36 2005 (43515E7C)
    b6562000 b65b9d80 tcpip tcpip.sys Fri Jan 13 04:28:12 2006 (43C7103C)
    b65ba000 b65cc400 ipsec ipsec.sys Wed Aug 04 08:14:27 2004 (41107EC3)
    b8744000 b8747a00 kbdhid kbdhid.sys Wed Aug 04 07:58:33 2004 (41107B09)
    b8754000 b8756f80 mouhid mouhid.sys Fri Aug 17 22:47:57 2001 (3B7D82FD)
    b8770000 b8780480 nvarm nvarm.sys Wed Apr 13 21:34:21 2005 (425D743D)
    b8781000 b8866000 nvmcp nvmcp.sys Wed Apr 13 21:34:21 2005 (425D743D)
    b8866000 b8889980 portcls portcls.sys Wed Aug 04 08:15:47 2004 (41107F13)
    b888a000 b88ef300 nvapu nvapu.sys Wed Apr 13 21:34:01 2005 (425D7429)
    b891d000 b8950200 update update.sys Wed Aug 04 07:58:32 2004 (41107B08)
    b8951000 b8981100 rdpdr rdpdr.sys Wed Aug 04 08:01:10 2004 (41107BA6)
    b8982000 b8992e00 psched psched.sys Wed Aug 04 08:04:16 2004 (41107C60)
    b8993000 b89a9680 ndiswan ndiswan.sys Wed Aug 04 08:14:30 2004 (41107EC6)
    b89aa000 b89bd900 parport parport.sys Wed Aug 04 07:59:04 2004 (41107B28)
    b89be000 b89d1780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 08:07:04 2004 (41107D08)
    b89d2000 b8d4d340 nv4_mini nv4_mini.sys Fri Mar 10 02:40:42 2006 (4410CB0A)
    b8d4e000 b8d80d80 NVSNPU NVSNPU.SYS Wed Apr 06 12:22:01 2005 (4253B849)
    b8d81000 b8dc0f00 NVNRM NVNRM.SYS Wed Apr 06 12:22:11 2005 (4253B853)
    b956a000 b9572d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 08:08:18 2004 (41107D52)
    b957a000 b9582f80 LHidUsbK LHidUsbK.Sys Wed Mar 29 02:55:19 2006 (4429DAF7)
    b95aa000 b95b6200 dump_CLASSPNP dump_CLASSPNP.SYS Wed Aug 04 08:14:26 2004 (41107EC2)
    b9866000 b9868f00 ws2ifsl ws2ifsl.sys Fri Aug 17 22:55:58 2001 (3B7D84DE)
    ba0fc000 ba104880 Fips Fips.SYS Sat Aug 18 03:31:49 2001 (3B7DC585)
    ba11c000 ba124700 netbios netbios.sys Wed Aug 04 08:03:19 2004 (41107C27)
    ba12c000 ba13ad80 arp1394 arp1394.sys Wed Aug 04 07:58:28 2004 (41107B04)
    ba13c000 ba144700 wanarp wanarp.sys Wed Aug 04 08:04:57 2004 (41107C89)
    ba1c1000 ba1c3280 rasacd rasacd.sys Fri Aug 17 22:55:39 2001 (3B7D84CB)
    ba428000 ba430300 NVENETFD NVENETFD.sys Wed Apr 06 12:22:26 2005 (4253B862)
    ba498000 ba4a6b80 drmk drmk.sys Wed Aug 04 08:07:54 2004 (41107D3A)
    ba4a8000 ba4b1480 NDProxy NDProxy.SYS Fri Aug 17 22:55:30 2001 (3B7D84C2)
    ba54a000 ba56c680 ks ks.sys Wed Aug 04 08:15:20 2004 (41107EF8)
    ba594000 ba596580 hidusb hidusb.sys Fri Aug 17 23:02:16 2001 (3B7D8658)
    ba5ac000 ba5afc80 mssmbios mssmbios.sys Wed Aug 04 08:07:47 2004 (41107D33)
    baa38000 baa46d80 sysaudio sysaudio.sys Wed Aug 04 08:15:54 2004 (41107F1A)
    baa48000 baa57d80 serial serial.sys Wed Aug 04 08:15:51 2004 (41107F17)
    baa58000 baa64880 rasl2tp rasl2tp.sys Wed Aug 04 08:14:21 2004 (41107EBD)
    baa68000 baa77900 Cdfs Cdfs.SYS Wed Aug 04 08:14:09 2004 (41107EB1)
    baa78000 baa82200 raspppoe raspppoe.sys Wed Aug 04 08:05:06 2004 (41107C92)
    baa88000 baa93d00 raspptp raspptp.sys Wed Aug 04 08:14:26 2004 (41107EC2)
    baa98000 baaa0900 msgpc msgpc.sys Wed Aug 04 08:04:11 2004 (41107C5B)
    baaa8000 baab1f00 termdd termdd.sys Wed Aug 04 07:58:52 2004 (41107B1C)
    baab8000 baac6100 usbhub usbhub.sys Wed Aug 04 08:08:40 2004 (41107D68)
    baac8000 baad6000 AmdK8 AmdK8.sys Mon Mar 07 23:58:10 2005 (422CCE72)
    baad8000 baae5080 nvax nvax.sys Wed Apr 13 21:32:41 2005 (425D73D9)
    baae8000 baaf2380 imapi imapi.sys Wed Aug 04 08:00:12 2004 (41107B6C)
    baaf8000 bab04180 cdrom cdrom.sys Wed Aug 04 07:59:52 2004 (41107B58)
    bab08000 bab16080 redbook redbook.sys Wed Aug 04 07:59:34 2004 (41107B46)
    baba0000 baba6f00 avg7rsxp avg7rsxp.sys Thu Feb 23 01:39:36 2006 (43FCF638)
    babc8000 babc9000 fdc fdc.sys unavailable (00000000)
    babd0000 babd6980 LHidKE LHidKE.Sys Wed Mar 29 02:56:06 2006 (4429DB26)
    babd8000 babde180 HIDPARSE HIDPARSE.SYS Wed Aug 04 08:08:15 2004 (41107D4F)
    babe0000 babe5200 vga vga.sys Wed Aug 04 08:07:06 2004 (41107D0A)
    babe8000 babeca80 Msfs Msfs.SYS Wed Aug 04 08:00:37 2004 (41107B85)
    babf0000 babf4880 TDI TDI.SYS Wed Aug 04 08:07:47 2004 (41107D33)
    babf8000 babfc580 ptilink ptilink.sys Fri Aug 17 22:49:53 2001 (3B7D8371)
    bac00000 bac06000 kbdclass kbdclass.sys Wed Aug 04 07:58:32 2004 (41107B08)
    bac08000 bac0c080 raspti raspti.sys Fri Aug 17 22:55:32 2001 (3B7D84C4)
    bac10000 bac15a00 mouclass mouclass.sys Wed Aug 04 07:58:32 2004 (41107B08)
    bac18000 bac1f880 Npfs Npfs.SYS Wed Aug 04 08:00:38 2004 (41107B86)
    bac20000 bac24500 watchdog watchdog.sys Wed Aug 04 08:07:32 2004 (41107D24)
    bac90000 bac94280 usbohci usbohci.sys Wed Aug 04 08:08:34 2004 (41107D62)
    bac98000 bac9e800 usbehci usbehci.sys Wed Aug 04 08:08:34 2004 (41107D62)
    baca0000 baca7b80 usbccgp usbccgp.sys Wed Aug 04 08:08:45 2004 (41107D6D)
    bad68000 bad6b280 nvnetbus nvnetbus.sys Wed Apr 06 12:22:28 2005 (4253B864)
    bad88000 bad8bc80 serenum serenum.sys Wed Aug 04 07:59:06 2004 (41107B2A)
    bad8c000 bad8e580 ndistapi ndistapi.sys Fri Aug 17 22:55:29 2001 (3B7D84C1)
    badb6000 badb7360 avgtdi avgtdi.sys Thu Aug 25 11:59:58 2005 (430D969E)
    bade6000 bade7a80 ParVdm ParVdm.SYS Fri Aug 17 22:49:49 2001 (3B7D836D)
    bae02000 bae03080 avg7rsw avg7rsw.sys Tue Jul 26 14:10:51 2005 (42E6284B)
    bae4c000 bae4d100 swenum swenum.sys Wed Aug 04 07:58:41 2004 (41107B11)
    bae4e000 bae4f280 USBD USBD.SYS Fri Aug 17 23:02:58 2001 (3B7D8682)
    bae56000 bae57f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 22:49:37 2001 (3B7D8361)
    bae58000 bae59080 Beep Beep.SYS Fri Aug 17 22:47:33 2001 (3B7D82E5)
    bae5a000 bae5b080 RDPCDD RDPCDD.sys Fri Aug 17 22:46:56 2001 (3B7D82C0)
    baedb000 baedbb80 Null Null.SYS Fri Aug 17 22:47:39 2001 (3B7D82EB)
    bafd4000 bafd4d00 dxgthk dxgthk.sys Fri Aug 17 22:53:12 2001 (3B7D8438)
    baffb000 baffbc00 audstub audstub.sys Fri Aug 17 22:59:40 2001 (3B7D85BC)
    bf800000 bf9c1180 win32k win32k.sys Thu Oct 06 02:05:44 2005 (43446A58)
    bf9c2000 bf9d3580 dxg dxg.sys Wed Aug 04 08:00:51 2004 (41107B93)
    bf9d4000 bfd9ce00 nv4_disp nv4_disp.dll Fri Mar 10 02:31:16 2006 (4410C8D4)
    Unloaded modules:
    b44e2000 b450c000 kmixer.sys
    Checksum: 00000000
    baf4a000 baf4b000 drmkaud.sys
    Checksum: 00000000
    b45d4000 b45f7000 aec.sys
    Checksum: 00000000
    ba10c000 ba119000 DMusic.sys
    Checksum: 00000000
    ba14c000 ba15a000 swmidi.sys
    Checksum: 00000000
    bae04000 bae06000 splitter.sys
    Checksum: 00000000
    ba10c000 ba115000 processr.sys
    Checksum: 00000000
    ba1c5000 ba1c9000 kbdhid.sys
    Checksum: 00000000
    ba14c000 ba159000 i8042prt.SYS
    Checksum: 00000000
    babd0000 babd5000 Cdaudio.SYS
    Checksum: 00000000
    ba1c9000 ba1cc000 Sfloppy.SYS
    Checksum: 00000000
    babb8000 babbd000 Flpydisk.SYS
    Checksum: 00000000
    LostUser
    LostUser Inactive
    I tried to make sense of the logs but debugger logs in XP aren't my forte. I see the obvious ERROR messages in the second log that point to symbols for a lot of the nvidia related files. I'm not sure what 'symbols' refers to.
    I do have a few questions though.
    What led up to having the problem initially? Did you just build a brand new system and had problems? Put in a new video card? What made you think it was the video driver?
    Maybe your video memory, video cooling. Try a different/generic video card if you have one (or the onboard video) to see if you still have problems.
    More info on the beginning of the problem would help.
  5. 2006/04/22
    cpc2004
    cpc2004 Inactive
    Hardware and software problem
    Hi,
    Your windows is crashed with multiple culprits. Bugcheck 7F and C2 is usually related to faulty ram. The stack trace of the minidump also have the footprint of nt!KeWaitForSingleObject and it is sign of faulty ram. Run memtest to stress test the ram.
    Your version of nVidia Firewall (ie NVTcp.sys) has timestamp 43515E7C and this version has software problem which causes blue screen. Refer the following cases
    http://www.techspot.com/vb/showthread.php?p=262019#post262019
  6. 2006/04/22
    zombie
    Thanks cpc2004,
    I did run memtest for 1 complete pass and a bit... should i run it again longer?
    I will have a look at the nvidia firewall thing. No more blue screens or errors since i posted though, hold thumbs :p.
  7. 2006/04/24
    zombie
    Had a blue screen this morning after leaving the PC on over night. This time it was bug check 0xC5. If it would help I could post the dump data, but I still need to have a look at the nvidia firewall thing, haven't had a chance yet. I'm quite sure it's not faulty RAM because I ran memtest again this morning and it completed 9 passes without any errors.
    Will keep you posted. Thanks for the help! :)
  8. 2006/04/25
    cpc2004
    cpc2004 Inactive
    Hi,
    Some faulty ram can pass memtest. The best method to diagnostoc ram problem is last known good ram (ie replace the ram from another PC which has blue screen issue).
  9. 2006/04/26
    zombie
    Well after setting Azureus as not offloadable in active armor, the machine made it through the night without BSOD, and through most of the day. So far so good. Looks like it might be a specific problem between Azureus and nvidia firewall. I'll see if it stays stable but looking good for now! :)
  10. 2006/04/27
    zombie
    It seems the problem is solved. If anyone else was having similar problems I hope this helps!
