Dual booting problems.
Discussion in 'Windows XP' started by mike25569, 2006/09/22.
  1. 2006/09/22
    mike25569
    mike25569 Inactive Thread Starter
    so i bought a new hard drive and installed windows x64 pro on it and i was hoping it was going to dual boot with my existing hard drive which has regular xp pro on it but it doesn't want to go past POST screen..and i cant even enter to the BIOS. the jumper settings are..x64 hard drive=master and the old hard drive=slave..i also tried cabal select for both drives and it still gets stuck..
    ive dual booted windows xp pro before just fine and i cant figure out why its not doing it :/ maybe i cant have both?
  2. 2006/09/22
    The general rule for dual booting is to install the oldest OS first. Changing the old drive to slave probably messed things up.
    mike25569
    hm so im going to try to put old one as master and new one as slave >.<
  5. 2006/09/22
    Mike - Welcome to the Board :)
    You most certainly can have both if not more - I have run systems in the past with quad boot to XP Pro, XP x64, W98 and Vista.
    Point is - how did you set this up?
    XP Pro drive as master - new hard drive as slave, or both CS I guess. Boot from the x 64 CD and follow the onscreen prompts to install x 64 on the new drive. A boot menu will be created automatically. You must have both drives connected when you install x 64.
  6. 2006/09/22
    mike25569
    kk it works :D now to find x64 drivers..>.< any1 kno if cannon has 64 bit printer drivers?
  7. 2006/09/23
    Canon has to be the first port of call :)
