Drop XP Components Not Wise?
Discussion in 'Windows XP' started by dbltrbl, 2002/05/17.
  1. 2002/05/17
    dbltrbl
    dbltrbl Inactive Thread Starter
    Would like to remove some functions not needed, such as: Mobile Option Pack, Net Meeting, Mapping Network Drives.. (No mobile device and don't operate within a network)
    Is it correct that MS put a "troll under the bridge" by connecting the sum of all the parts into the core files, making it unwise to remove anything? If memory is correct, the component particularly mentioned is "MSN "...Thanks!
  2. 2002/05/17
    Zephyr
    Zephyr Inactive
    I wouldn't do it. You have little to gain and some of that stuff may remove components that you need elsewhere.
    The understanding of the component integration of XP will take some time and it's best left to others. ;)
    Given that you really didn't ask for my opinion, I'll amend this post by saying, if you remove any features from XP, use the Add/Remove feature of Control Panel and always have good backups in case something goes awry.
    Rancher
    Rancher Inactive
    inf folder
    The INF folder has the "SYSOC.INF" file that HIDES things from ya. First however, you must have SHOW HIDDEN files & FOLDERS enabled to view the inf folder. Path is C:\windows\inf
    Open the sysoc.inf with notepad & look for the lines that have hide in them. You may edit these (caution) & these componets will then show in "add/remove programs" EXAMPLE:pinball=ocgen.dll,OcEntry,pinball.inf,HIDE,7
    you can remove hide back to the coma, leaving 2 comas between inf & 7 save/exit, go to add/remove & pinball can be removed now.:D I've removed msn & msmsgr as well
  5. 2002/05/18
    dbltrbl
    Very Handy!
    Thanks Rancher! Your explanation stands to reason, as opposed to search defaults messed up...dbl
  6. 2002/05/18
    Zephyr
    Zephyr Inactive
    You guys go ahead up on the point, I'll ride drag. Let me know how it works out, especially if you hit a snag later.
  7. 2002/05/18
    Rancher
    Rancher Inactive
    Don't you like ta live on the edge Zephyr :D If we hit white water & go over the falls you WILL be there, eh:)
    Actually I do it all the time coz I gotta know 'bout these things, like who uses wordpad? Unhide the thang & uninstall etc. & that pain in the arse msngr.................hmmmm
