Resolved Driver require for HP 1015 printer for W7
Discussion in 'Windows 7' started by Signode, 2014/03/04.
  1. 2014/03/04
    Signode
    Signode Well-Known Member Thread Starter
    Hi;
    I just got a second hand HP 1015 printer. Wanted to install its driver but system did not load it automatically when connect the printer. Unfortunately I am unable to find the driver via Google it to install manually. Please help me out.
  2. 2014/03/04
    Hi, I assume that the Computer you are installing this HP 1015 printer on is not the one in your System Details?
    Usually Generic drivers will be installed by the Wizard.
    You should be able to get the Drivers from the link that MrBill has Posted.
    Even brand new HP printers these days are supplied with a CD with the Software to install, but the CD offers you the choice of going direct to HP for the latest Drivers. Just make sure you have the Model numbers correct and the Serial number in case it's needed. Neil.
