drivecleaner/winantivirus problems
Discussion in 'Malware and Virus Removal Archive' started by ontheroad, 2006/10/02.
  1. 2006/10/02
    ontheroad
    ontheroad Inactive Thread Starter
    I am having the same problem that many others are experiencing with DC and WAV. I have downloaded and run all the suggested removal programs but this trojan persists. Any help would be appreciated.
    I downloaded HTL and ran it but I don't know how to intrepret the results.
    Thanks in advance
    OTR
  2. 2006/10/02
    TeMerc
    TeMerc Inactive Alumni
    Well, now that's why you're here isn't it? :p
    If you would, please paste your log file into this thread and be sure HJT is installed as instructed below.
    For proper HJT installation please place HJT into ITS OWN PERMANANT FOLDER. This folder should not be on the desktop.
    You can do this by going to My Computer (Windows key+e) then double click on C: then right click and select New then Folder and name it HJT. (C:\HJT\HijackThis.exe)Move HijackThis.exe into this folder. When you run HijackThis.exe from C:\HJT folder and have it "Fixed checked" it will create a backup file of modifications to use if restore is necessary which is easily accessible.
