Resolved Download Problems
Discussion in 'Windows XP' started by kiaville, 2008/05/21.
  1. 2008/05/21
    kiaville
    kiaville Well-Known Member Thread Starter
    Hi! I am trying to install a driver update for my printer. I download ok but when I click to unzip I get this message "Object reference not set to an instance of an object ". What is going on and how can I solve this problem? Thanks.
  2. 2008/05/21
    Does right clicking and selecting Extract help?
    kiaville
    No it doesn't. There isn't a right click menu. It extracts then the message pops up.
  5. 2008/05/21
    Download it first. Do not choose 'Open'.
    kiaville
    It's downloaded as zip file. How do you install it without opening it?
  7. 2008/05/21
    surferdude2
    surferdude2 Inactive
    Post a link to the download and I'll see if the file unzips for me. Perhaps the file is corrupt.
  8. 2008/05/22
    kiaville
    surferdude2
    The file seems to be OK. It is evidently a firmware flashing tool (self-executing zipped file) so I won't be able to execute it successfully since I do not have that same printer.
    I downloaded it (FW_5000_829.exe) without incident.
    Then I double clicked it and it ran without incident but showed no report of having done anything, not even in the Event Viewer.
    I then right clicked it and used Winzip to unzip it to its own folder without any error. I then ran the executable file that was revealed in that folder and it gave me an error to the effect that the particular device or drive was not present. I would expect that.
    Other than telling you to be sure the printer is on-line and standing by when running the file, I can't take you any further.
    Good luck!
  10. 2008/05/22
    Best try downloading it again - delete your existing download first.
  11. 2008/05/22
    kiaville
    I think something is wrong on my pc but I don't have a clue. All other downloads seem to be ok. I have tried it 5 times so far. When I do a web search about this message it refers to an SDK problem but it's not related to this situation. Thanks for the input.
