Download problem
Discussion in 'General Internet' started by alindsey, 2003/02/15.
  1. 2003/02/15
    alindsey
    alindsey Inactive Thread Starter
    I run XP Home. when I download a file, lets say "file.exe," the extention .JPG is added at the end. Thus the file's downloaded name would be "file.exe.jpg." Anyone know where to fix this problem? Thanks, Austin
  2. 2003/02/15
    Dennis L Inactive Alumni
    Hi alindsey
    Welcome to the forums
    What browser are you using? This occurs occasionally in Netscape 7's.... Go to .....
    Edit/Preferences/Navigator/Helper Applications. Look for an octet-stream listing. If the extension type is .jpg, then delete it. Also your download file is usable. Browse to the file, "rename" by removing the incorrect file extension. If you do NOT want to correct/use the file, it SHOULD be deleted.
    alindsey
    :) Dennis you're great.! That fixed the problem. When God said I'm passing out brains, I thought he said rain.
    Kindest regards, Austin
