Resolved down loading files and applications fail
Discussion in 'Windows 7' started by Bearclaw, 2017/04/17.
  1. 2017/04/17
    Bearclaw
    Bearclaw Well-Known Member Thread Starter
    231
    Computer Experience:
    Intermediate
    I get the message '.exe is not a valid Win32 application' when I try to download files/applications. This show up when I attempt to download anything it seems. I cannot seem to get this resolved.
    any ideas or suggestions would be most appreciated.
    HP 6000 64 bit Laptop
    Windows Home Premium 7
  2. 2017/04/17
    1,093
    Fairfax, VA
    echo $experienced;
    Need to know:
    1. Which Web browser are you using?
    2. Are you choosing "Save file" or "Run".
    Bearclaw
    231
    Intermediate
    I was using Firefox when the problem first showed up. After that I have found the same situation with IE and Chrome. I have also uninstalled Firefox in hope of doing a reinstall that might 'reset' things back to a working status but alas I now cannot even download the Firefox exe.
    I think this situation may have developed after a pretty extensive Windows update but as some time had elapsed from the updates to my noticing the trouble I really can't be sure if that might be the source of troubles.
  5. 2017/04/18
    Bearclaw
    231
    Intermediate
    Just for informational purposes. I managed to get this problem resolved by running a Registry Cleaner. If I experience this issue again I will post it and keep it all current. Hope this might be of use to others.
  6. 2017/04/18
    1,093
    New Zealand
    intermediate
    FWIW, when you installed Firefox originally, did you RUN or SAVE the Mozilla download? If you saved the download, it should be in your Download Folder. You can always install from that and update once it's running OK. ;)
  7. 2017/04/18
    Bearclaw
    231
    Intermediate
    Thanks for the information, In my situation there was no option to do a save, once I clicked on the link it came back with the 'invalid' message. There is one particular exe. file I am not able to get a usable copy of although it seems to download just fine but gives me the message 'exe. .... could not be saved because the source file could not be read'. I believe this is a message generated when there is an incomplete or corrupt file. Still working on finding a different source for the desired application.
  8. 2017/04/18
    1,093
    New Zealand
    intermediate
    If you Download from Mozilla you have SAVE as your only option. This a Binary file and every time I've used it, it is saved in my Download Folder. I have Firefox 52.0 in Downloads and it Runs from there.
  9. 2017/04/19
    Bearclaw
    231
    Intermediate
    yes, the Default folder for downloads via Firefox is the Download folder. You can change that if you wish by going to the TOOLS tab then OPTIONS, the second item is where you can enter a new place.
  10. 2017/04/20
    1,093
    New Zealand
    intermediate
    Have you tried running SFC to see if you have corrupted files?
