Double clicking?
Discussion in 'Windows XP' started by JulienS, 2006/01/23.
  1. 2006/01/23
    JulienS
    JulienS Inactive Thread Starter
    Each time that I click something with my mouse it always double clicks. Like if I press the print button once, its gonna print twice. I donno if its something wrong with the mouse or something wrong with the computer. Any help is appreciated.
  2. 2006/01/23
    If its a Logitech mouse and you have Mouseware installed, make sure that you have not reassigned the left key to double click.
    JulienS - Welcome to the Board :)
    In Windows Explorer go Tools > Folder Options > General Tab and check that 'Single click to open an item' is not checked.
    If that's OK probably an oversensitive/failing mouse or it is set up as rsinfo suggests. Same settings available for MS mice in Intellipoint (Control Panel > Mouse)
  5. 2006/01/24
    JulienS
    Thanks for the tips. Pete you were right the mouse was oversensitive. I mess around with some configuration of the mouse and seems to be workin now :)
    Thanks alot
  6. 2006/01/25
    You're welcome :) Stick around - this is a great place to hang out :D
