Double-click opens search window
Discussion in 'Windows XP' started by tuneguy, 2007/01/27.
  1. 2007/01/27
    tuneguy
    tuneguy Inactive Thread Starter
    One of my XP computers does an annoying thing: when I double click on an icon or folder, instead of opening and displaying the contents like it should, the search window opens instead as if I had selected "search" in the start menu. Weird and annoying...anybody know how to fix it?
    Thanks in advance
    T
  2. 2007/01/27
    surferdude2
    surferdude2 Inactive
    http://www.dougknox.com/xp/scripts_desc/xp_folder_open.htm
    FYI, This quirk is most often caused by opening Explorer or My Computer and clicking on the Tools > Folder Options > File Types > File Folder and selecting "Advanced" then clicking OK instead of Cancel. Even though you have only looked and made no changes, changes will nevertheless be made IF you have selected "Advanced" and IF you then click OK. To avoid this, always click "Cancel" when you don't intend to change things.
    As an alternate to the above fix, you can go to Start >Run and type:
    regsvr32 /i shell32.dll
    Press enter. The effect is immediate with no reboot required.
    tuneguy
    Thanks, surferdude
    Strange, but when I got to the Advanced pane under Tools > Folder Options > File Types > File Folder I wasn't able to delete the "Find" command in the window. (Edit remained gray-ed out) but when i typed in the commands you suggested in the Run box it worked. Bingo! Thanks again.
    t
