Does FF have a window to enter Trusted Sites?
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by robls99, 2015/11/09.
  1. 2015/11/09
    robls99 Lifetime Subscription
    robls99 Well-Known Member Thread Starter
    I am used to the IE window under Secutity for entering links for Trusted Sites which facilitates opening certain sites.
    Does FF have something similar?
  2. 2015/11/09
    antik
    antik Well-Known Member
    Nothing in firefox is directly equivalent to the IE trusted site.
    When you open a site, you can right click the page, select View Page Info
    and then click Permissions.
    The choices you make there may make that site work better for you.
    When "Use Default" is checked, the grayed out area shows the default choice.
    robls99 likes this.
    antik,
    Thanks a lot, Ill give it a try!
    Since you answered 2 of my new postings with great info in only just a couple of hours, you get a HUGE THANK YOU!!!
    Rob
  5. 2015/11/10
    antik
    Rob - You are welcome. Live long and prosper.
