Documents And Settings
Discussion in 'Windows XP' started by jonathan, 2004/06/06.
  1. 2004/06/06
    jonathan
    jonathan Inactive Thread Starter
    i have a problem documents and setting in my computer, when you go to documents and setting in my computer it only shows default user and me
    trevor negus but it does not show all users, is this a problem. If i go to
    start menu and click explore all users, i can see all 3 setting namely default
    user, trevor negus and all users.the same also applies if i go to windows explorer it also only shows me the two folders but not all users folder.
    How can i correct this problem so that both my computer and explorer
    shows all 3 folders?Why if you go to start menu can i see all 3 folders?
    please can somebody help me!!!!!!!!!!!!
  2. 2004/06/06
    jonathan
    i have manage to get all users in my computer and explorer but it is a shortcut and not file folder like trevor negus and default user. it is a solution in the meantime but if somebody knows how i an get all users back with file folder type i will appreciate it.
    thank you
    trevor
    noahdfear
    noahdfear Inactive
  5. 2004/06/06
    jonathan
    my problem has being fixed, thank you
  6. 2004/06/06
    How about sharing exactly how you fixed it. Very possible that tomorrow or next week or next month, someone else will have the same problem and will find this thread.
    #5
