DMA problem?
Discussion in 'PC Hardware' started by jrl117, 2002/05/10.
  1. 2002/05/10
    jrl117
    jrl117 Inactive Thread Starter
    Im having a Dma problem, I think.
    I my device manager i show 2 seprate Dma's one ok the other has a yellow ! next to it.
    For the life of me i cant figure out what/where the problem is.
    I will list the info from the to Dma's as if u hit the properties tab in devices.
    Dma #1-good one.
    Settings-all are on defaults Reserve memory-0,Addy restrictions 4GB
    Driver -Driver is Vmm32.vxd(vdmad.vxd)
    Resources-Use auto setttings checked,6 in/out range 0000-000f,0081-0083,0087-0087,0089-008B,008F-008F,00C0-00DF are the settings for in/out's, and DMA 04 is last setting, and this is also not showing any conflicts
    Dma #2-Bad one
    Under general info, the VDMAD.VXD device loader(s) for this device could not load the device driver.(code 2)
    Settings- Res mem 0,unchecked, Addy restriction,unchecked, 4GB
    Driver info is same as one above. Vmm32.vxd(vdmad.vxd)
    Resources- Mega conflicts here. Lotsa red circles with lines through them.
    Automatic settings is checked. Resources type(All are conflicting cept one)
    DMA-04, In/Out 0000-000f,0080-0090,0094-009f(this one not conflicting),00C0-00DF
    System is p2-500, 512ram, win98,Geforce2 32mg vid,SB sound card...
    Please feel free to let me know if you need more info about my system
    Here is a little more info might help someone out.This from Microsoft system info in system tools.
    Direct memory access controller System
    This Device Has a Problem: Code=2 (0x2)
    Device failure: Try changing the driver for this device. If that doesn't work,see your hardware documentation.
    Registry Key:HKEY_LOCAL_MACHINE\enum\ACPI\*PNP0200\0
    Dont know if that helps or not, hopefully someone can help me figure this out. Biggest thing I guess is what the failure is. System seems to run fine....
    Ok well thank you for your help if u happen to be able to help
    Jrl117
  2. 2002/05/10
    Rancher
    Rancher Inactive
    dma
    You should tell us more about your system. guessing here now that ya have a virtual device driver prob *.VXD &/or memory as in VMM32can =virtual memory manager. Perhaps you have a hardware device & removed it & the vxd is still lookin'? Zip drive? Parralel passthro to scanner? External cdrom, etc?:)
    The box will still run fine but the yellow "Splats" will stay in DM
    jrl117
    Dma problem
    Thank you for the reply.
    Fixed the one problem with the extra?Dma.
    Now just dealing with alot of little things...but think I got them whipped......Thnx again.
