Disconnect problem!
Discussion in 'General Internet' started by HippoTank, 2002/09/01.
  1. 2002/09/01
    HippoTank
    HippoTank Inactive Thread Starter
    :mad: It is very annoying. I'll tell you my problem first then my PC's stuff.
    Well, I can surf the internet ok, and everything is fine. But if i say, try to have a MSN messenger voice conversation, or start netmeeting, I get disconnected! It also happens when i play Worms Armageddon online, or Graal online but NOT when i play red alert 2 online.
    I don't know if it is my Computer, or my ISP. I have a feeling that there is an option somewhere that i can change to fix my problem.
    I have NTL always on 128k broadband, that goes from the modem in my digital set top box, to my USB port. I have windows ME, and my connection is annalysed by CorrectConnect.
    Can someone Pleeeease help me??? :confused:
  2. 2002/09/05
    HippoTank
    :confused:
    brett
    brett Inactive Alumni
    Trim your startup menu, remove any programs which you no longer use, update everything which can be updated (drivers, DirectX, etc) run Scandisk, run defragmenter and then cross your fingers.
  5. 2002/09/05
    HippoTank
    ok, i'll try that. P.S does it have anything do do with proxy?
    As it says:
    PROXY: DISABLED
    DNS: DISABLED
    DHCP: ENABLED
  6. 2002/09/05
    brett
    No.
  7. 2002/09/11
    Helia
    Helia Inactive
    Hello If you have windows xp I believe there is a fix for it and also think its for windows 2000
    Let me know..I read it in the sp1 Pack for xp go to windows xp on the baord and read Arie post on windows xp sp1 its in there under lists of fixes I cnt url it in here it wont work Or maybe I am not doing it rite who knows lol
