Difficulty setting up "Sync" program, PC to phone
Discussion in 'Mobile Devices' started by Alex Ethridge, 2014/08/31.
  1. 2014/08/31
    Alex Ethridge
    I'm trying to set up a synchronization between my PC and phone for several folders on my PC containing MP3, DOC, RTF, WAV and JPG files.
    Using Samsung Galaxy S5 with Windows 7 PC, a program called Sync (from Google Play) installed on the phone and Sync client installed on PC.
    I have downloaded the Sync manual; but, the illustrations in the manual don't look anything like what appears on my screen. From the two images pasted below, you can see my screen looks stark naked against what the manual shows should be there.
    If you care to see the manual, it is here.
    I've been trying to solve this synchronization problem for several days. Android 4+ does not allow direct access to the storage media on Samsung phones and does not allow drive letter access. It also places severe restrictions drag-n-drop that makes copying only files with later dates, impossible.
  2. 2014/09/01
    Manual picture is from the Mac version. That's going to look different.
    Your picture looks as clean as the screenshots in the Play Store..
