Diable UST Sticks and allow access to USB Storage Devices
Discussion in 'Windows XP' started by raghuprasad, 2009/03/02.
  1. 2009/03/02
    raghuprasad
    raghuprasad Inactive Thread Starter
    Hi All,
    I need to disable the USB Devices like mouse, keyboard to my machine, but i need to allow user to access the USB Storage devices like pen drive or external hdd. Please help me to achieve this.
    Thanks & Regards,
    Raghu
  2. 2009/03/03
    Your thread title ....
    and your post are entirely different .....
    If you disable the mouse and keyboard the end result is obvious - an unusable computer? :confused:
    Please clarify.
  5. 2009/03/03
    Ah... you read better then me :eek:
    raghuprasad
    Thanks for the reply, i use a touch pad computer and i want my user only to use my application. So i dont want user to connect a keyboard for operating the machine. Am using Windows XP with Sp3.
  7. 2009/03/04
    You could consider disabling the USB controllers in Device Manager - this will of course prevent any USB devices from operating.
    If the user account does not have Administrative rights then it should not be possible for the user to re-enable them.
