Dell Latitude D600 (XP) won't recognize hard drive disk for boot sequence
Discussion in 'Windows XP' started by clitwin13, 2011/01/10.
  1. 2011/01/10
    clitwin13 Lifetime Subscription
    clitwin13 Well-Known Member Thread Starter
    Currently inherited a Dell Latitude D600 Laptop with XP installed ... was told it was running slower and slower and now will not boot ..Error message is not boot device is available...shows Primary Hard Drive: None... any suggestions?
  2. 2011/01/10
    Capt. Jack Sparrow
    Capt. Jack Sparrow Inactive
    clitwin13 likes this.
    Does the hard drive light come on when you attempt to boot the computer?
    Check out the hard drive with the manufacturer's disk diagnostic software - DOS version from a bootable CD (instructions on most manufacturer's website) ....
    Disk Diagnostic Software ....
    ExcelStore
    Hitachi/IBM
    Samsung
    Seagate, Maxtor, Quantum
    Western Digital
    You will have to physically examine the drive to determine the manufacturer. While you are inside the box remove and remake the power and data cable (at both ends) connections.
  5. 2011/01/11
    Thank you both for your timely response ...I will take your suggestions and get back with the results....ckl
