Dead Screen Error, can any one help?? (debuglog included)
Discussion in 'Windows Server System' started by smasher86, 2006/04/21.
  1. 2006/04/21
    smasher86
    smasher86 Inactive Thread Starter
    Hello i have some Problems with my server!
    OS: Windows 2000 Server SP4
    Im Getting Dead(blue) Screen Error
    I didn see whats the Error bz i were not at the place that moment...
    On the Server i Have one Accounting program for NetCafe
    And software like AVG 7.1 - Antivirus
    here is the DebugLog
    Opened log file 'C:\debuglog.txt'
    1: kd> .sympath srv*c:\symbols*http://msdl.microsoft.com/download/symbols
    Symbol search path is: srv*c:\symbols*http://msdl.microsoft.com/download/symbols
    1: kd> .reload;!analyze -v;r;kv;lmnt;.logclose;q
    Loading Kernel Symbols
    Loading unloaded module list
    Loading User Symbols
    * Bugcheck Analysis *
    NTFS_FILE_SYSTEM (24)
    If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
    Arguments:
    Arg1: 0019025e
    Arg2: f68379fc
    Arg3: f6837654
    Arg4: 8046ca32
    Debugging Details:
    *** Your debugger is not using the correct symbols ***
    *** In order for this command to work properly, your symbol path ***
    *** must point to .pdb files that have full type information. ***
    *** Certain .pdb files (such as the public OS symbols) do not ***
    *** contain the required information. Contact the group that ***
    *** provided you with these symbols if you need this command to ***
    *** work. ***
    *** Type referenced: ntfs!_IRP_CONTEXT ***
    BUGCHECK_STR: 0x24_F6837654
    DEFAULT_BUCKET_ID: INTEL_CPU_MICROCODE_ZERO
    LAST_CONTROL_TRANSFER: from bff0e7a6 to bfee5ff1
    STACK_TEXT:
    f6837548 bff0e7a6 87bfec08 f6837574 80460b1b Ntfs!NtfsExceptionFilter+0xcf
    f6837d78 80417481 00000000 00000000 00000000 Ntfs!NtfsFspClose+0x1ae
    f6837da8 80455a82 00000000 00000000 00000000 nt!ExpWorkerThread+0xaf
    f6837ddc 8046b012 804173d2 00000000 00000000 nt!PspSystemThreadStartup+0x54
    00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
    FOLLOWUP_IP:
    Ntfs!NtfsExceptionFilter+cf
    bfee5ff1 e90393ffff jmp Ntfs!NtfsExceptionFilter+0xcf (bfedf2f9)
    SYMBOL_STACK_INDEX: 0
    FOLLOWUP_NAME: MachineOwner
    SYMBOL_NAME: Ntfs!NtfsExceptionFilter+cf
    MODULE_NAME: Ntfs
    IMAGE_NAME: Ntfs.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 3ebc05a5
    STACK_COMMAND: kb
    FAILURE_BUCKET_ID: 0x24_F6837654_Ntfs!NtfsExceptionFilter+cf
    Followup: MachineOwner
    eax=8906313c ebx=00000024 ecx=c00000d8 edx=8046b6a6 esi=87bfec08 edi=c0000005
    eip=bfee5ff1 esp=f6837528 ebp=c0000188 iopl=0 nv up ei ng nz na po nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
    Ntfs!NtfsExceptionFilter+0xcf:
    f6837548 bff0e7a6 87bfec08 f6837574 80460b1b Ntfs!NtfsExceptionFilter+0xcf (FPO: [Uses EBP] [2,0,4])
    f6837d78 80417481 00000000 00000000 00000000 Ntfs!NtfsFspClose+0x1ae (FPO: [Non-Fpo])
    f6837da8 80455a82 00000000 00000000 00000000 nt!ExpWorkerThread+0xaf (FPO: [Non-Fpo])
    f6837ddc 8046b012 804173d2 00000000 00000000 nt!PspSystemThreadStartup+0x54 (FPO: [Non-Fpo])
    start end module name
    80062000 80076460 hal halmacpi.dll Fri Mar 21 06:04:42 2003 (3E7A733A)
    80400000 8059dd00 nt ntkrnlmp.exe Wed Jun 11 01:42:11 2003 (3EE650B3)
    a0000000 a01a35a0 win32k win32k.sys Fri May 02 07:47:08 2003 (3EB1EA3C)
    bcd63000 bcd72a20 ipsec ipsec.sys Wed Apr 30 03:04:59 2003 (3EAF051B)
    bcecb000 bcf06bc0 srv srv.sys Wed Apr 30 03:05:07 2003 (3EAF0523)
    bd153000 bd15b240 Fips Fips.SYS Tue May 09 19:28:29 2000 (39182E9D)
    bd193000 bd1b04a0 afd afd.sys Wed Apr 30 12:45:29 2003 (3EAF8D29)
    bd4f1000 bd8e9980 nv4_disp nv4_disp.dll Fri Jan 30 05:22:55 2004 (4019B1EF)
    be80a000 be81f180 dump_atapi dump_atapi.sys Tue Apr 01 22:08:25 2003 (3E89D599)
    be848000 be86a3c0 Fastfat Fastfat.SYS Wed Jan 15 23:48:39 2003 (3E25BB17)
    be86b000 be9256e0 avg7core avg7core.sys Tue Feb 21 11:57:50 2006 (43FAC7FE)
    be926000 be98c240 mrxsmb mrxsmb.sys Fri May 23 02:46:57 2003 (3ECD5361)
    be99f000 be9c99c0 rdbss rdbss.sys Fri May 23 02:47:05 2003 (3ECD5369)
    be9ca000 be9f31a0 netbt netbt.sys Thu May 22 05:51:10 2003 (3ECC2D0E)
    bea1c000 bea6d060 tcpip tcpip.sys Wed Apr 30 03:05:31 2003 (3EAF053B)
    beabe000 beac3900 HIDPARSE HIDPARSE.SYS Tue Apr 08 21:34:46 2003 (3E930836)
    bead6000 beadbfa0 HIDCLASS HIDCLASS.SYS Wed Jan 15 23:45:26 2003 (3E25BA56)
    bfb88000 bfbb23a0 update update.sys Wed Apr 16 08:22:01 2003 (3E9CDA69)
    bfbb3000 bfbd2d00 ks ks.sys Wed Dec 04 21:09:38 2002 (3DEE36D2)
    bfbf7000 bfbf9c60 mouhid mouhid.sys Wed Jan 15 23:43:39 2003 (3E25B9EB)
    bfbfb000 bfc11ba0 ndiswan ndiswan.sys Wed Apr 30 03:05:01 2003 (3EAF051D)
    bfc12000 bfc3c980 yukonw2k yukonw2k.sys Tue Dec 23 17:09:06 2003 (3FE83E72)
    bfc3d000 bfc5eb20 USBPORT USBPORT.SYS Mon Mar 10 19:47:39 2003 (3E6CB39B)
    bfc5f000 bfe2a100 nv4_mini nv4_mini.sys Fri Jan 30 05:28:43 2004 (4019B34B)
    bfe2b000 bfe2ef60 HPZipr12 HPZipr12.sys Thu Mar 18 15:22:43 2004 (40598683)
    bfe3b000 bfe3e020 usbscan usbscan.sys Wed Jan 15 23:45:45 2003 (3E25BA69)
    bfe4b000 bfe4e580 vga vga.sys Sat Sep 25 22:37:40 1999 (37ED1674)
    bfe9b000 bfeb0640 Mup Mup.sys Wed Jan 15 23:54:01 2003 (3E25BC59)
    bfeb1000 bfedaaa0 NDIS NDIS.sys Wed Apr 30 03:05:01 2003 (3EAF051D)
    bfedb000 bff5d5a0 Ntfs Ntfs.sys Fri May 09 23:46:45 2003 (3EBC05A5)
    bff5e000 bff6f7c0 KSecDD KSecDD.sys Thu Mar 27 01:37:44 2003 (3E821DA8)
    bff70000 bff821c0 Dfs Dfs.sys Wed Feb 12 06:19:06 2003 (3E49AF1A)
    bff83000 bff98180 atapi atapi.sys Tue Apr 01 22:08:25 2003 (3E89D599)
    bff99000 bffba9c0 dmio dmio.sys Wed Jan 15 23:47:04 2003 (3E25BAB8)
    bffbb000 bffd7220 ftdisk ftdisk.sys Tue Apr 01 02:21:58 2003 (3E88BF86)
    bffd8000 bffffc20 ACPI ACPI.sys Wed Jan 15 23:44:22 2003 (3E25BA16)
    f6400000 f640e6a0 pci pci.sys Wed Jan 15 23:44:07 2003 (3E25BA07)
    f6410000 f6419220 ohci1394 ohci1394.sys Wed Jan 15 23:46:43 2003 (3E25BAA3)
    f6420000 f6429e20 1394BUS 1394BUS.SYS Tue Apr 08 09:56:58 2003 (3E9264AA)
    f6430000 f643b680 isapnp isapnp.sys Wed Jan 15 23:43:47 2003 (3E25B9F3)
    f6440000 f6448700 CLASSPNP CLASSPNP.SYS Wed Jan 15 23:42:51 2003 (3E25B9BB)
    f6470000 f647c4c0 VIDEOPRT VIDEOPRT.SYS Wed Jan 15 23:47:20 2003 (3E25BAC8)
    f6480000 f648f400 serial serial.sys Wed Apr 16 08:19:39 2003 (3E9CD9DB)
    f6490000 f649b680 i8042prt i8042prt.sys Wed Apr 16 08:00:59 2003 (3E9CD57B)
    f64a0000 f64aca80 rasl2tp rasl2tp.sys Wed Apr 30 03:05:06 2003 (3EAF0522)
    f64b0000 f64bbc40 raspptp raspptp.sys Thu May 15 03:47:00 2003 (3EC2D574)
    f64c0000 f64cea20 parallel parallel.sys Wed Jan 15 23:47:14 2003 (3E25BAC2)
    f64d0000 f64d9be0 usbhub usbhub.sys Wed Mar 19 03:30:41 2003 (3E77AC21)
    f64e0000 f64ec160 usbhub20 usbhub20.sys Wed Jan 15 23:45:59 2003 (3E25BA77)
    f6500000 f6509ce0 NDProxy NDProxy.SYS Fri Oct 01 03:25:35 1999 (37F3F16F)
    f6510000 f6518fa0 Npfs Npfs.SYS Sun Oct 10 03:58:07 1999 (37FFD68F)
    f6520000 f6528680 msgpc msgpc.sys Wed Jan 15 23:54:25 2003 (3E25BC71)
    f6530000 f65381a0 netbios netbios.sys Tue Oct 12 23:34:19 1999 (38038D3B)
    f6550000 f655c680 HPZid412 HPZid412.sys Thu Mar 18 15:22:40 2004 (40598680)
    f6570000 f657efe0 Cdfs Cdfs.SYS Wed Apr 16 07:58:53 2003 (3E9CD4FD)
    f6680000 f6685520 PCIIDEX PCIIDEX.SYS Tue Feb 25 22:31:08 2003 (3E5BB66C)
    f6688000 f668f140 MountMgr MountMgr.sys Wed Feb 05 00:15:15 2003 (3E401F53)
    f6690000 f6697720 disk disk.sys Wed Jan 15 23:43:05 2003 (3E25B9C9)
    f6698000 f669d100 agp440 agp440.sys Wed Jan 15 23:47:07 2003 (3E25BABB)
    f66b0000 f66b7f40 uhcd uhcd.sys Wed Jan 15 23:45:50 2003 (3E25BA6E)
    f66c0000 f66c5400 mouclass mouclass.sys Thu Feb 20 20:37:45 2003 (3E550459)
    f66c8000 f66ccfc0 USBD USBD.SYS Wed Jan 22 21:05:33 2003 (3E2ECF5D)
    f66d8000 f66dcc00 usbehci usbehci.sys Tue May 06 00:50:04 2003 (3EB6CE7C)
    f66e0000 f66e5240 Msfs Msfs.SYS Wed Oct 27 03:21:32 1999 (3816377C)
    f66e8000 f66ef000 fdc fdc.sys unavailable (FFFFFFFE)
    f6700000 f6706100 parport parport.sys Wed Jan 15 23:47:13 2003 (3E25BAC1)
    f6708000 f670d3e0 HPZius12 HPZius12.sys Thu Mar 18 15:21:01 2004 (4059861D)
    f6710000 f6715ec0 kbdclass kbdclass.sys Thu Feb 20 20:37:30 2003 (3E55044A)
    f6720000 f6726c40 cdrom cdrom.sys Wed Jan 15 23:43:04 2003 (3E25B9C8)
    f6728000 f672fd00 wanarp wanarp.sys Fri Aug 16 16:25:01 2002 (3D5CEF1D)
    f6738000 f673d460 usbprint usbprint.sys Wed Jan 15 23:44:07 2003 (3E25BA07)
    f6740000 f6744400 ptilink ptilink.sys Wed Jan 15 23:47:15 2003 (3E25BAC3)
    f6750000 f67540e0 raspti raspti.sys Sat Oct 09 00:45:10 1999 (37FE57D6)
    f6758000 f675e000 npptNT2 npptNT2.sys Thu Jan 06 10:43:06 2005 (41DCDDFA)
    f6778000 f677ca60 flpydisk flpydisk.sys Wed Jan 15 23:42:52 2003 (3E25B9BC)
    f6780000 f6786920 avg7rsnt avg7rsnt.sys Thu Feb 23 03:39:31 2006 (43FCF633)
    f6790000 f6796a20 EFS EFS.SYS Wed Jan 15 23:46:55 2003 (3E25BAAF)
    f6810000 f6812a20 BOOTVID BOOTVID.dll Thu Nov 04 05:24:33 1999 (3820E051)
    f6814000 f6816d00 PartMgr PartMgr.sys Wed Jan 15 23:43:07 2003 (3E25B9CB)
    f68a0000 f68a3640 serenum serenum.sys Wed Jan 15 23:47:01 2003 (3E25BAB5)
    f68a8000 f68ab540 hidusb hidusb.sys Tue Oct 05 03:03:30 1999 (37F93242)
    f68ac000 f68ae540 gameenum gameenum.sys Wed Jan 15 23:45:32 2003 (3E25BA5C)
    f68b4000 f68b62e0 ndistapi ndistapi.sys Wed Jan 15 23:54:15 2003 (3E25BC67)
    f68c4000 f68c7e60 TDI TDI.SYS Wed Jan 15 23:56:26 2003 (3E25BCEA)
    f6900000 f6901d20 Diskperf Diskperf.sys Thu Feb 13 01:34:38 2003 (3E4ABDEE)
    f6902000 f6903b80 dmload dmload.sys Wed Jan 15 23:47:06 2003 (3E25BABA)
    f6908000 f6909940 serscan serscan.sys Sat Sep 25 22:36:06 1999 (37ED1616)
    f6914000 f6915ca0 Fs_Rec Fs_Rec.SYS Wed Jan 15 23:53:30 2003 (3E25BC3A)
    f691c000 f691de40 rasacd rasacd.sys Sat Sep 25 22:41:23 1999 (37ED1753)
    f692a000 f692b080 avg7rsw avg7rsw.sys Tue Jul 26 16:10:51 2005 (42E6284B)
    f6934000 f6935860 ParVdm ParVdm.SYS Tue Sep 28 07:28:16 1999 (37F035D0)
    f69c8000 f69c8f80 WMILIB WMILIB.SYS Sat Sep 25 22:36:47 1999 (37ED163F)
    f69c9000 f69c9b00 pciide pciide.sys Wed Jan 15 23:43:03 2003 (3E25B9C7)
    f69e1000 f69e1a40 audstub audstub.sys Sat Sep 25 22:35:33 1999 (37ED15F5)
    f69e2000 f69e3000 swenum swenum.sys Wed Dec 04 21:10:07 2002 (3DEE36EF)
    f69e5000 f69e59e0 Null Null.SYS Sat Sep 25 22:34:58 1999 (37ED15D2)
    f69e6000 f69e6ee0 Beep Beep.SYS Thu Oct 21 02:18:59 1999 (380E3FD3)
    f69e7000 f69e7f80 mnmdd mnmdd.SYS Sat Sep 25 22:37:40 1999 (37ED1674)
    f69e8000 f69e8f80 dump_WMILIB dump_WMILIB.SYS Sat Sep 25 22:36:47 1999 (37ED163F)
    Unloaded modules:
    bc049000 bc057000 swmidi.sys
    Checksum: 00000000
    bbfd2000 bbff7000 portcls.sys
    Checksum: 00000000
    bc039000 bc046000 DMusic.sys
    Checksum: 00000000
    bbfad000 bbfd2000 kmixer.sys
    Checksum: 00000000
    bc059000 bc065000 sysaudio.sys
    Checksum: 00000000
    bbff7000 bc009000 wdmaud.sys
    Checksum: 00000000
    bd261000 bd26d000 sysaudio.sys
    Checksum: 00000000
    bd069000 bd07b000 wdmaud.sys
    Checksum: 00000000
    bcff7000 bd01c000 kmixer.sys
    Checksum: 00000000
    bd01c000 bd041000 portcls.sys
    Checksum: 00000000
    f6580000 f658d000 DMusic.sys
    Checksum: 00000000
    bd251000 bd25f000 swmidi.sys
    Checksum: 00000000
    bc9de000 bc9f3000 VGA.dll
    Checksum: 00000000
    bd8d5000 bd8ea000 VGA.dll
    Checksum: 00000000
    bd4f1000 bd8ea000 nv4_disp.dll
    Checksum: 00000000
    f6540000 f6549000 redbook.sys
    Checksum: 00000000
    f66a8000 f66ad000 Cdaudio.SYS
    Checksum: 00000000
    bfe53000 bfe56000 Sfloppy.SYS
    Checksum: 00000000
    Closing open log file C:\debuglog.txt
    Can any one Help me with this?
    Im Getting errors may be once in a 24h...
    and some times ive seen the error calls "BAD_POOL_CALLER "
  2. 2006/04/22
    cpc2004
    cpc2004 Inactive
    chkdsk /r
    Hi,
    Bugcheck code 24 and C2 is usually caused by faulty ram or invalid logical disk I/O node. Run chkdsk /r and memtest to stress test the ram.
    SpywareDr
