dead monitor
Discussion in 'PC Hardware' started by Jerry72, 2003/09/21.
  1. 2003/09/21
    Jerry72
    Jerry72 Inactive Thread Starter
    KDS monitor,17 ".Will not turn on.Power cable checked ok on another monitor.What further check can I make before sending it for repair?
  2. 2003/09/23
    FireDancer Lifetime Subscription
    FireDancer Inactive
    Hi,
    If it is under some kind of warranty I would send it in and not touch it as you
    would have to open it up and that would
    void a warranty.
    It might be easier and cheaper to just buy a new one :)
    Regards,
    ~FIREDANCER~
    NC Music
    NC Music Inactive
    May be simple
    You probably have already checked this, but I have 3 KDS 17" monitors and found the cables need to have a very solid connection to video to work. If it is loose, you can get problems from missing 1 color to the problem you describe. Those monitors will shut down unless they have a signal coming in. Most people push the connectors on the back of their computer and dont bother to tighten the screws. You will want to tighten the screws with these monitors.
  5. 2003/09/24
    Jerry72
    dead monito
    To NC MUSIC,
    Thanks.I was trying to plug it in without connecting the cable to to the video.
    Jerry
