Cursor Problem?
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by jpChris, 2003/10/03.
  1. 2003/10/03
    jpChris
    jpChris Inactive Thread Starter
    Hi,
    Ever since I installed NS 7.1 my cursor stays a cursor instead of changing into a pointing finger when I'm on a link. The links turn a different color and I can click and go. But some links don't change color and it makes it difficult to distinguish if it's a link or not.
    Any ideas?
    OS: WinXP Pro.
    Thanks.
    Chris
  2. 2003/10/08
    Antony
    Antony Inactive
    Is it just one particular website? or all links?
    Some webmaters like to trick visitors.
    jpChris
    Hi Antony,
    No, it's everywhere; all sites and links.
    Chris
  5. 2003/10/13
    Antony
    Antony Inactive
    hmm,
    Have you checked the Windows Control Panel? the Mouse and the Pointer...
    Next I will assume you did not apply anything to your self, such as in userContent.css.
    So try create a new Netscape user account and see if it still exist.
    If still, then I can only suggest you to re-install Netscape 7.1 again.
  6. 2003/10/16
    jpChris
    Hi Antony,
    Sorry it took so long to get back to you. I checked where you said and nothing had changed. My default for the pointer was a regular cursor and it would change to a pointing finger when I was on the web, but nowhere else; which is exactly as I wanted.
    However, when I downloaded IE6 (SP1) Security Updates, there must have been something in the patch that caused the cursor to do what IT wanted to do and not me.
    So, I reset the Link Select to the system default and my pointing finger is back. But it's back everywhere else on my system, too. I only wanted it for the web and nowhere else.
    Oh, well, thanks "Uncle Bill. "
    And, thank you, Antony :D
    Chris
