Resolved Crtl-Alt-Del Popup Problem
Discussion in 'Windows XP' started by SVEN, 2012/09/22.
  1. 2012/09/22
    SVEN
    SVEN Well-Known Member Thread Starter
    Hi All,
    I have a strange problem.
    It used to be when I hit Crtl-Alt-Del, I get a popup that shows me all the programs running and I can click on other tabs to let me know what processes are running. I think there where 2 more tabs, but don’t remember what they where.
    Now when I do this I only get a single popup, no tabs, I can’t even X it out because there is no X and I can not close it from the task bar either. The only way to get rid of it is by right clicking on the green icon in the sys tray and closing it from there.
    Also, I used to be able to hit Crtl-Alt-Del twice to shut down the computer, no more.
    Enclosed is a screen shot of what I get when hitting C-A-D
    Any one knows what happened and how to restore it?
    Sven
    SVEN,
  2. 2012/09/22
    Flatiron2
    Flatiron2 Well-Known Member
    SVEN
    That did it,
    Thank you very much
    Sven
    SVEN,
