Crash Dump Help
Discussion in 'Windows XP' started by jasonv2, 2006/07/28.
  1. 2006/07/28
    jasonv2
    jasonv2 Inactive Thread Starter
    Hi,
    I have a user complaing about crashes, two in two days, none the previous year. Windows XP SP2 and all updates, AMD64. I am new do deciphering crash dumps soany advice you can offer is appreciated.
    thanks,
    Jason
    The dump analysis is as follows:
    Microsoft (R) Windows Debugger Version 6.6.0003.5
    Loading Dump File [C:\Documents and Settings\jasonv\Desktop\Minidump\Mini071106-01.dmp]
    Executable search path is:
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 2600.xpsp_sp2_gdr.050301-1519
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
    Debug session time: Tue Jul 11 10:51:56.432 2006 (GMT-7)
    System Uptime: 1 days 2:44:25.187
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 10000050, {80000008, 0, bf816599, 0}
    Could not read faulting driver name
    Probably caused by : win32k.sys ( win32k!xxxInternalDoPaint+18 )
    Followup: MachineOwner
    kd> !analyze -v
    PAGE_FAULT_IN_NONPAGED_AREA (50)
    Invalid system memory was referenced. This cannot be protected by try-except,
    it must be protected by a Probe. Typically the address is just plain bad or it
    is pointing at freed memory.
    Arguments:
    Arg1: 80000008, memory referenced.
    Arg2: 00000000, value 0 = read operation, 1 = write operation.
    Arg3: bf816599, If non-zero, the instruction address which referenced the bad memory
    address.
    Arg4: 00000000, (reserved)
    Debugging Details:
    READ_ADDRESS: 80000008
    FAULTING_IP:
    bf816599 397e08 cmp [esi+0x8],edi
    MM_INTERNAL_CODE: 0
    CUSTOMER_CRASH_COUNT: 1
    BUGCHECK_STR: 0x50
    LAST_CONTROL_TRANSFER: from bf81657a to bf816599
    STACK_TEXT:
    b1031c44 bf81657a 80000000 e2c22820 e2c22820 win32k!xxxInternalDoPaint+0x18
    b1031c68 bf81657a bc6fc360 e2c22820 00000220 win32k!xxxInternalDoPaint+0x68
    b1031c8c bf816679 bc6f06e8 e2c22820 00000220 win32k!xxxInternalDoPaint+0x68
    b1031ca8 bf801b4b 00000000 b1031d14 b1031d64 win32k!xxxDoPaint+0x66
    b1031ce8 bf80373a b1031d14 000025ff 00000000 win32k!xxxRealInternalGetMessage+0x39a
    b1031d48 8053c808 0007fed4 00000000 00000000 win32k!NtUserPeekMessage+0x40
    b1031d48 7c90eb94 0007fed4 00000000 00000000 nt!KiFastCallEntry+0xf8
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    0007fe88 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: .bugcheck ; kb
    FOLLOWUP_IP:
    FAULTING_SOURCE_CODE:
    SYMBOL_STACK_INDEX: 0
    FOLLOWUP_NAME: MachineOwner
    SYMBOL_NAME: win32k!xxxInternalDoPaint+18
    MODULE_NAME: win32k
    IMAGE_NAME: win32k.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 43446a58
    FAILURE_BUCKET_ID: 0x50_win32k!xxxInternalDoPaint+18
  2. 2006/07/28
    Try running the dump through our tool.
    jasonv2
    ok, thanks for the tip.
    BTW there is a error in the default string your program runs, the output file is listed as c:temp\debuglog.txt, it obviously was not appearing.
    Here is the output:
    Opened log file 'c:\debuglog.txt'
    <snip>
    BugCheck 10000050, {80000068, 0, bf8b9685, 0}
    Probably caused by : win32k.sys ( win32k!SpbTransfer+c )
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    Arguments:
    Arg1: 80000068, memory referenced.
    Arg3: bf8b9685, If non-zero, the instruction address which referenced the bad memory
    address.
    Debugging Details:
    READ_ADDRESS: 80000068
    FAULTING_IP:
    bf8b9685 8b4368 mov eax,[ebx+0x68]
    MM_INTERNAL_CODE: 0
    BUGCHECK_STR: 0x50
    LAST_CONTROL_TRANSFER: from bf8b966b to bf8b9685
    STACK_TEXT:
    a4fe8b60 bf8b966b e44353b8 80000000 00000001 win32k!SpbTransfer+0xc
    a4fe8b88 bf8b9643 e44353b8 bc8051c0 00000001 win32k!SpbTransfer+0x77
    a4fe8bcc bf82abdb bc8051c0 00000000 01010053 win32k!CreateSpb+0x28b
    a4fe8c34 bf829037 bc6f06e8 bf9a9fe0 bf9a9fe0 win32k!zzzChangeStates+0x447
    a4fe8c7c bf8276a3 bf9a9fe0 00000000 bc7a6000 win32k!zzzBltValidBits+0xe2
    a4fe8cd4 bf82a3be 00000001 00000000 a4fe8d24 win32k!xxxEndDeferWindowPosEx+0x121
    a4fe8cf4 bf82b62a bc7a6000 00000000 000007ee win32k!xxxSetWindowPos+0x101
    a4fe8d40 8053c808 bc7a6000 00000000 000007ee win32k!NtUserSetWindowPos+0x163
    a4fe8d40 7c90eb94 bc7a6000 00000000 000007ee nt!KiFastCallEntry+0xf8
    0c94e770 00000000 00000000 00000000 00000000 0x7c90eb94
    FOLLOWUP_IP:
    SYMBOL_NAME: win32k!SpbTransfer+c
    MODULE_NAME: win32k
    FAILURE_BUCKET_ID: 0x50_win32k!SpbTransfer+c
    eax=00000000 ebx=80000000 ecx=89e69074 edx=e1b8a740 esi=bc8051c0 edi=00000000
    eip=bf8b9685 esp=a4fe8b4c ebp=a4fe8b60 iopl=0 nv up ei ng nz na po nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00210286
    win32k!SpbTransfer+0xc:
    bf8b9685 8b4368 mov eax,[ebx+0x68] ds:0023:80000068=????????
    a4fe8b60 bf8b966b e44353b8 80000000 00000001 win32k!SpbTransfer+0xc (FPO: [Non-Fpo])
    a4fe8b88 bf8b9643 e44353b8 bc8051c0 00000001 win32k!SpbTransfer+0x77 (FPO: [Non-Fpo])
    a4fe8bcc bf82abdb bc8051c0 00000000 01010053 win32k!CreateSpb+0x28b (FPO: [Non-Fpo])
    a4fe8c34 bf829037 bc6f06e8 bf9a9fe0 bf9a9fe0 win32k!zzzChangeStates+0x447 (FPO: [Non-Fpo])
    a4fe8c7c bf8276a3 bf9a9fe0 00000000 bc7a6000 win32k!zzzBltValidBits+0xe2 (FPO: [Non-Fpo])
    a4fe8cd4 bf82a3be 00000001 00000000 a4fe8d24 win32k!xxxEndDeferWindowPosEx+0x121 (FPO: [Non-Fpo])
    a4fe8cf4 bf82b62a bc7a6000 00000000 000007ee win32k!xxxSetWindowPos+0x101 (FPO: [Non-Fpo])
    a4fe8d40 8053c808 bc7a6000 00000000 000007ee win32k!NtUserSetWindowPos+0x163 (FPO: [Non-Fpo])
    a4fe8d40 7c90eb94 bc7a6000 00000000 000007ee nt!KiFastCallEntry+0xf8 (FPO: [0,0] TrapFrame @ a4fe8d64)
    start end module name
    804d7000 806cd280 nt ntkrnlpa.exe Tue Mar 01 16:34:37 2005 (42250A1D)
    806ce000 806ee380 hal halaacpi.dll Tue Aug 03 22:59:05 2004 (41107B29)
    a49bd000 a49e6f00 kmixer kmixer.sys Tue Aug 03 23:07:46 2004 (41107D32)
    a5031000 a5053080 RDPWD RDPWD.SYS Thu Jun 09 16:52:39 2005 (42A8D647)
    a5138000 a513b800 asyncmac asyncmac.sys Tue Aug 03 23:05:02 2004 (41107C8E)
    a5284000 a52c4100 HTTP HTTP.sys Fri Oct 08 16:48:20 2004 (41672744)
    a5d80000 a5dd1400 srv srv.sys Thu Apr 20 23:12:25 2006 (444877C9)
    a5dfa000 a5e73d80 amon amon.sys Tue Jun 14 00:46:47 2005 (42AE8B67)
    a5e9c000 a5ec8400 mrxdav mrxdav.sys Tue Aug 03 23:00:49 2004 (41107B91)
    a6008000 a601c400 wdmaud wdmaud.sys Tue Aug 03 23:15:03 2004 (41107EE7)
    a8d47000 a8d59e00 dump_viasraid dump_viasraid.sys Thu Oct 30 01:38:31 2003 (3FA0DC17)
    a8f8b000 a8f8f500 watchdog watchdog.sys Tue Aug 03 23:07:32 2004 (41107D24)
    a901a000 a9028d80 sysaudio sysaudio.sys Tue Aug 03 23:15:54 2004 (41107F1A)
    a905a000 a9069900 Cdfs Cdfs.SYS Tue Aug 03 23:14:09 2004 (41107EB1)
    b2037000 b2037d00 dxgthk dxgthk.sys Fri Aug 17 13:53:12 2001 (3B7D8438)
    b2fd5000 b2fd8a00 kbdhid kbdhid.sys Tue Aug 03 22:58:33 2004 (41107B09)
    b3b33000 b3b39780 USBSTOR USBSTOR.SYS Tue Aug 03 23:08:44 2004 (41107D6C)
    b3caf000 b3cb1f80 mouhid mouhid.sys Fri Aug 17 13:47:57 2001 (3B7D82FD)
    b3f04000 b3f06580 hidusb hidusb.sys Fri Aug 17 14:02:16 2001 (3B7D8658)
    b50c3000 b50cbd80 HIDCLASS HIDCLASS.SYS Tue Aug 03 23:08:18 2004 (41107D52)
    b58ff000 b5901900 Dxapi Dxapi.sys Fri Aug 17 13:53:19 2001 (3B7D843F)
    b5c10000 b5c30f00 ipnat ipnat.sys Wed Sep 29 15:28:36 2004 (415B3714)
    b5c31000 b5c9fa00 mrxsmb mrxsmb.sys Fri May 05 02:41:42 2006 (445B1DD6)
    b5cbc000 b5cbf780 dump_scsiport dump_scsiport.sys Tue Aug 03 22:59:51 2004 (41107B57)
    b5cc8000 b5cf2a00 rdbss rdbss.sys Fri May 05 02:47:55 2006 (445B1F4B)
    b5cf3000 b5d14d00 afd afd.sys Tue Aug 03 23:14:13 2004 (41107EB5)
    b5d15000 b5d3cc00 netbt netbt.sys Tue Aug 03 23:14:36 2004 (41107ECC)
    b5e01000 b5e58d80 tcpip tcpip.sys Thu Apr 20 04:51:47 2006 (444775D3)
    b5e59000 b5e6b400 ipsec ipsec.sys Tue Aug 03 23:14:27 2004 (41107EC3)
    b6f8e000 b6f9cd80 arp1394 arp1394.sys Tue Aug 03 22:58:28 2004 (41107B04)
    b6f9e000 b6fa6700 wanarp wanarp.sys Tue Aug 03 23:04:57 2004 (41107C89)
    b6fae000 b6fb6880 Fips Fips.SYS Fri Aug 17 18:31:49 2001 (3B7DC585)
    b6fbe000 b6fc6700 netbios netbios.sys Tue Aug 03 23:03:19 2004 (41107C27)
    b709e000 b70a5880 Npfs Npfs.SYS Tue Aug 03 23:00:38 2004 (41107B86)
    b70a6000 b70a8f00 ws2ifsl ws2ifsl.sys Fri Aug 17 13:55:58 2001 (3B7D84DE)
    b70ae000 b70b0280 rasacd rasacd.sys Fri Aug 17 13:55:39 2001 (3B7D84CB)
    b8c52000 b8c85200 update update.sys Tue Aug 03 22:58:32 2004 (41107B08)
    b8c86000 b8c8aa80 Msfs Msfs.SYS Tue Aug 03 23:00:37 2004 (41107B85)
    b8c8e000 b8c93200 vga vga.sys Tue Aug 03 23:07:06 2004 (41107D0A)
    b8c96000 b8c9c180 HIDPARSE HIDPARSE.SYS Tue Aug 03 23:08:15 2004 (41107D4F)
    b8cb6000 b8cbb000 flpydisk flpydisk.sys Tue Aug 03 22:59:24 2004 (41107B3C)
    b8cd6000 b8d06100 rdpdr rdpdr.sys Tue Aug 03 23:01:10 2004 (41107BA6)
    b9148000 b9158e00 psched psched.sys Tue Aug 03 23:04:16 2004 (41107C60)
    b9159000 b916f680 ndiswan ndiswan.sys Tue Aug 03 23:14:30 2004 (41107EC6)
    b9170000 b9183900 parport parport.sys Tue Aug 03 22:59:04 2004 (41107B28)
    b9184000 b91a7980 portcls portcls.sys Tue Aug 03 23:15:47 2004 (41107F13)
    b91a8000 b93d5d40 ALCXWDM ALCXWDM.SYS Tue Oct 26 22:57:33 2004 (417F38CD)
    b93d6000 b93f8e80 USBPORT USBPORT.SYS Tue Aug 03 23:08:34 2004 (41107D62)
    b93f9000 b941b680 ks ks.sys Tue Aug 03 23:15:20 2004 (41107EF8)
    b941c000 b9452b00 yk51x86 yk51x86.sys Thu Nov 25 23:42:27 2004 (41A6DE63)
    b9453000 b9466780 VIDEOPRT VIDEOPRT.SYS Tue Aug 03 23:07:04 2004 (41107D08)
    b9467000 b96e8700 nv4_mini nv4_mini.sys Mon Aug 02 20:37:12 2004 (410F0868)
    b9e7d000 b9e85900 msgpc msgpc.sys Tue Aug 03 23:04:11 2004 (41107C5B)
    ba56c000 ba56e580 ndistapi ndistapi.sys Fri Aug 17 13:55:29 2001 (3B7D84C1)
    ba570000 ba572980 gameenum gameenum.sys Tue Aug 03 23:08:20 2004 (41107D54)
    ba574000 ba577c80 serenum serenum.sys Tue Aug 03 22:59:06 2004 (41107B2A)
    ba59c000 ba5b6580 Mup Mup.sys Tue Aug 03 23:15:20 2004 (41107EF8)
    ba5b7000 ba5e3a80 NDIS NDIS.sys Tue Aug 03 23:14:27 2004 (41107EC3)
    ba5e4000 ba670480 Ntfs Ntfs.sys Tue Aug 03 23:15:06 2004 (41107EEA)
    ba671000 ba687780 KSecDD KSecDD.sys Tue Aug 03 22:59:45 2004 (41107B51)
    ba688000 ba699f00 sr sr.sys Tue Aug 03 23:06:22 2004 (41107CDE)
    ba69a000 ba6b8780 fltmgr fltmgr.sys Tue Aug 03 23:01:17 2004 (41107BAD)
    ba6b9000 ba6cbe00 viasraid viasraid.sys Thu Oct 30 01:38:31 2003 (3FA0DC17)
    ba6cc000 ba6e3800 SCSIPORT SCSIPORT.SYS Tue Aug 03 22:59:39 2004 (41107B4B)
    ba6e4000 ba70b000 fasttx2k fasttx2k.sys Tue Aug 05 19:43:02 2003 (3F306B36)
    ba70b000 ba722480 atapi atapi.sys Tue Aug 03 22:59:41 2004 (41107B4D)
    ba723000 ba748700 dmio dmio.sys Tue Aug 03 23:07:13 2004 (41107D11)
    ba749000 ba767880 ftdisk ftdisk.sys Fri Aug 17 13:52:41 2001 (3B7D8419)
    ba768000 ba778a80 pci pci.sys Tue Aug 03 23:07:45 2004 (41107D31)
    ba779000 ba7a6d80 ACPI ACPI.sys Tue Aug 03 23:07:35 2004 (41107D27)
    ba8a8000 ba8b0c00 isapnp isapnp.sys Fri Aug 17 13:58:01 2001 (3B7D8559)
    ba8b8000 ba8c6e80 ohci1394 ohci1394.sys Tue Aug 03 23:10:05 2004 (41107DBD)
    ba8c8000 ba8d5000 1394BUS 1394BUS.SYS Tue Aug 03 23:10:03 2004 (41107DBB)
    ba8d8000 ba8e2500 MountMgr MountMgr.sys Tue Aug 03 22:58:29 2004 (41107B05)
    ba8e8000 ba8f4c80 VolSnap VolSnap.sys Tue Aug 03 23:00:14 2004 (41107B6E)
    ba8f8000 ba900e00 disk disk.sys Tue Aug 03 22:59:53 2004 (41107B59)
    ba908000 ba914200 CLASSPNP CLASSPNP.SYS Tue Aug 03 23:14:26 2004 (41107EC2)
    ba988000 ba991480 NDProxy NDProxy.SYS Fri Aug 17 13:55:30 2001 (3B7D84C2)
    ba998000 ba9a0a00 processr processr.sys Tue Aug 03 22:59:14 2004 (41107B32)
    ba9a8000 ba9b6100 usbhub usbhub.sys Tue Aug 03 23:08:40 2004 (41107D68)
    ba9b8000 ba9c7180 nic1394 nic1394.sys Tue Aug 03 22:58:28 2004 (41107B04)
    ba9c8000 ba9d2380 imapi imapi.sys Tue Aug 03 23:00:12 2004 (41107B6C)
    ba9d8000 ba9e4180 cdrom cdrom.sys Tue Aug 03 22:59:52 2004 (41107B58)
    ba9e8000 ba9f6080 redbook redbook.sys Tue Aug 03 22:59:34 2004 (41107B46)
    baa08000 baa16b80 drmk drmk.sys Tue Aug 03 23:07:54 2004 (41107D3A)
    baa18000 baa27d80 serial serial.sys Tue Aug 03 23:15:51 2004 (41107F17)
    baa28000 baa34880 rasl2tp rasl2tp.sys Tue Aug 03 23:14:21 2004 (41107EBD)
    baa38000 baa42200 raspppoe raspppoe.sys Tue Aug 03 23:05:06 2004 (41107C92)
    baa48000 baa53d00 raspptp raspptp.sys Tue Aug 03 23:14:26 2004 (41107EC2)
    baad8000 baae1f00 termdd termdd.sys Tue Aug 03 22:58:52 2004 (41107B1C)
    bab28000 bab2e200 PCIIDEX PCIIDEX.SYS Tue Aug 03 22:59:40 2004 (41107B4C)
    bab30000 bab34900 PartMgr PartMgr.sys Fri Aug 17 18:32:23 2001 (3B7DC5A7)
    bab38000 bab3ce20 PxHelp20 PxHelp20.sys Tue Feb 01 15:23:42 2005 (42000F7E)
    bab40000 bab46d00 viaagp1 viaagp1.sys Wed Jul 02 03:08:01 2003 (3F02AF01)
    babb0000 babb5500 TDTCP TDTCP.SYS Tue Aug 03 22:58:52 2004 (41107B1C)
    babc0000 babc5000 usbuhci usbuhci.sys Tue Aug 03 23:08:34 2004 (41107D62)
    babc8000 babce800 usbehci usbehci.sys Tue Aug 03 23:08:34 2004 (41107D62)
    babd0000 babd1000 fdc fdc.sys unavailable (00000000)
    babe0000 babe4880 TDI TDI.SYS Tue Aug 03 23:07:47 2004 (41107D33)
    bac60000 bac64580 ptilink ptilink.sys Fri Aug 17 13:49:53 2001 (3B7D8371)
    bac68000 bac6c080 raspti raspti.sys Fri Aug 17 13:55:32 2001 (3B7D84C4)
    bac70000 bac76000 kbdclass kbdclass.sys Tue Aug 03 22:58:32 2004 (41107B08)
    bac78000 bac7da00 mouclass mouclass.sys Tue Aug 03 22:58:32 2004 (41107B08)
    bacb8000 bacbb000 BOOTVID BOOTVID.dll Fri Aug 17 13:49:09 2001 (3B7D8345)
    bad64000 bad67c80 mssmbios mssmbios.sys Tue Aug 03 23:07:47 2004 (41107D33)
    bad98000 bad9b280 ndisuio ndisuio.sys Tue Aug 03 23:03:10 2004 (41107C1E)
    bada8000 bada9b80 kdcom kdcom.dll Fri Aug 17 13:49:10 2001 (3B7D8346)
    badaa000 badab100 WMILIB WMILIB.SYS Fri Aug 17 14:07:23 2001 (3B7D878B)
    badac000 badad500 viaide viaide.sys Tue Aug 03 22:59:42 2004 (41107B4E)
    badae000 badaf700 dmload dmload.sys Fri Aug 17 13:58:15 2001 (3B7D8567)
    badda000 baddbb00 NTIDrvr NTIDrvr.sys Wed Jan 15 09:33:02 2003 (3E259B4E)
    baddc000 baddd420 ASACPI ASACPI.sys Thu Aug 12 19:52:52 2004 (411C2D04)
    bade2000 bade3400 pmemnt pmemnt.sys Thu Sep 30 08:51:09 1999 (37F386ED)
    badec000 baded100 swenum swenum.sys Tue Aug 03 22:58:41 2004 (41107B11)
    bae28000 bae29280 USBD USBD.SYS Fri Aug 17 14:02:58 2001 (3B7D8682)
    bae56000 bae57f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 13:49:37 2001 (3B7D8361)
    bae58000 bae59080 Beep Beep.SYS Fri Aug 17 13:47:33 2001 (3B7D82E5)
    bae5a000 bae5b080 mnmdd mnmdd.SYS Fri Aug 17 13:57:28 2001 (3B7D8538)
    bae5c000 bae5d080 RDPCDD RDPCDD.sys Fri Aug 17 13:46:56 2001 (3B7D82C0)
    bae70000 bae70b80 Null Null.SYS Fri Aug 17 13:47:39 2001 (3B7D82EB)
    baf70000 baf70b80 msmpu401 msmpu401.sys Fri Aug 17 13:59:59 2001 (3B7D85CF)
    baf71000 baf71c00 audstub audstub.sys Fri Aug 17 13:59:40 2001 (3B7D85BC)
    bf800000 bf9c1180 win32k win32k.sys Wed Oct 05 17:05:44 2005 (43446A58)
    bf9c2000 bf9d3580 dxg dxg.sys Tue Aug 03 23:00:51 2004 (41107B93)
    bf9d4000 bfd6ce80 nv4_disp nv4_disp.dll Mon Aug 02 20:32:55 2004 (410F0767)
    Unloaded modules:
    a49bd000 a49e7000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    a4a37000 a4a61000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    a4b01000 a4b2b000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    a4c1b000 a4c45000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    a4ce5000 a4d0f000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    a4d37000 a4d61000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    a4dd7000 a4e01000 kmixer.sys
    Checksum: 00000000
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  5. 2006/07/28
    Not much to go on, but you might try to check all your systems drivers.
    See: How to Use Driver Verifier to Troubleshoot Windows Drivers
    CRITICAL:
