CPU running 100% constantly...
Discussion in 'Internet Explorer & Microsoft Edge' started by Breakout, 2004/02/29.
  1. 2004/02/29
    Breakout
    Breakout Inactive Thread Starter
    I started a similiar thread in hardware, but after looking around I think this problem has something to do with IExplorer and the lastest security patch I installed Saturday.
    My CPU usage used to be around 5 to 10% when I wasn't doing anything, but now it's 100% all the time. (even in safemode)
    And my CPU is running hot at 55 degrees, should be around 46. Would doing a registry restore help?
    I have Win98SE...thanks
  2. 2004/02/29
    goddez1
    goddez1 Inactive
    For a starter why not find out what process is hogging the cpu resources?
    Recommedation: obtain the process viewer "TaskInfo2000 ",
    from http://www.iarsn.com
    Free to evaluate, USD $20 to register.
    What was this update you suspect is causing the problem?
    Breakout
    Thanks, here's a screenshot of Taskinfo. Maybe you can make heads or tails out of it.
    BTW...if those concerned can't get the screenshots, it's because it's that time of week (Sunday Nights) for RR to do maintenance.
    You might have to check back tomorrow...
    Screenshot
    This is the update that I suspect: Cumulative Security Update for Internet Explorer 6 Service Pack 1 (KB832894)
  5. 2004/02/29
    Zander
    Zander Geek Member Alumni
    I posted an answer here .
  6. 2004/03/01
    Breakout
    I have this topic going in the hardware section, also. Wasn't sure what was causing the problem. Maybe this belongs in the Win98 section...some kind of bug?
    Anyway, I downloaded a program that shows processes, and this is what shows for about 3 seconds, and then it goes away and shows normal cpu usage.
    I wonder if this is why "System Monitor" is always peaked at 100%? Maybe it's only seeing that first 3 seconds.
    Screenshot
  7. 2004/03/01
