Copy network connections
Discussion in 'Windows XP' started by catsystems, 2005/12/02.
  1. 2005/12/02
    catsystems
    catsystems Inactive Thread Starter
    Hi There,
    Is there a way to copy all your network connections out to another p.c..?
    Thanks in advance
    Rory
    :confused:
  2. 2005/12/02
    I've never seen or heard of a way to do it.
    skeet6961
    skeet6961 Inactive
    since the actual HW may/probably does vary, would it do u any good?
    an IPCONFIG /ALL > c:\netinfo.txt should give u enuff info to recreate them on any system.
  5. 2005/12/02
    ghemant
    ghemant Inactive
    Hi,
    why don't you try with some tool like GFI Lan Guard which audit your network and give you full information of your network and suggest you what to do for those vunerability you found with your pc and theirs a tool from Microsoft Security Analyzer .
    Regards
  6. 2005/12/06
    catsystems
    copy network connections...?
    Thanks for the replies guys however I should have been more specific.. we have a p.c. with about 80 VPN connections which are obviously kept in the network connections dialogue box and it is primarily these I don't want to have to re-create on another p.c.
    Cut & Paste would be great but then that would be too easy...! Even the files and transfer wizard will not copy them....
    I would be most gratefull for any further ideas
    Regards
    Rory
    :confused:
  7. 2005/12/06
