Control Panel Error
Discussion in 'Windows XP' started by MissDixi, 2007/07/01.
  1. 2007/07/01
    MissDixi
    MissDixi Inactive Thread Starter
    Lately when I have tried to use my Control Panel, I get a Microsoft error that says it has to shut down. When I use Dr. Watson to debug it, I get a message that says Dr. Watson has an error and has to shut down. I have no idea where to even start to figure this out. The error menu that appears wants me to send it to MS but no information shows up on why the error has appeared. This happens when I try to open control Panel or after I open Control Panel and try to click on an item choice. Any help/advice will be most appreciated. My operating system is Windows XP. Thankyou! :) MissDixi
  2. 2007/07/02
    mailman Lifetime Subscription
    mailman Geek Member
    Hi, MissDixi. Welcome to Windows BBS! :)
    Perhaps Windows XP's System File Checker (SFC) will help you resolve your issue.
    • Have your Windows XP CD handy because you may be prompted to insert it into your CD drive during this process.
    • Click Start > Run...
    • Type [FONT= "Courier New"][SIZE= "3"]sfc /scannow[/SIZE][/FONT] in the "Open:" field.
    • Click the OK button.
    A "Windows File Protection" window will open and display its progress. If SFC runs successfully without any intervention from you, it will take approximately 15-25 minutes to complete. When SFC completes, the "Windows File Protection" window will simply disappear.
    To see any changes that may have been made by SFC after it completes:
    • Type [FONT= "Courier New"][SIZE= "3"]eventvwr.msc[/SIZE][/FONT] in the "Open:" field.
    • Click the "System" item on the left side of the "Event Viewer" window.
    Any changes made by SFC will be displayed (in reverse order) as "Windows File Protection" events between Event ID 64016 (Windows File Protection started) and 64017 (Windows File Protection completed).
    Double-click on an event (or right-click on the event and select "Properties ") to view details about the event. You can use the up/down arrow buttons on the right side of the event's "Properties" window to view details about adjacent events without having to close the event's "Properties" window.
    If you want to copy event details to your clipboard (for pasting into Notepad or a forum message, for example), use the button immediately below the up/down arrow buttons in the event's "Properties" window.
