Resolved Constant Guard Protection Suite General ?
Discussion in 'Security and Privacy' started by DPI Graphics, 2014/04/28.
  1. 2014/04/28
    DPI Graphics
    DPI Graphics Well-Known Member Thread Starter
    Is anyone using Constant Guard Protection Suite by xfinity?
    Is it truly safe to use for password protection?
  2. 2014/04/28
    Hi DPI Graphics. I've never used that program mainly because there are better alternatives for security out there that do a better job.
    Hopefully someone will be able to give you a better answer but that program is something that I don't waste my time using.
    DPI Graphics likes this.
    James Martin
    James Martin Geek Member
    Use Roboform instead.
    A pro license is only $30.00, and you also get 24/7 support at no extra charge.
    I prefer the desktop license, but there are other options available too.
    For what it's worth, you can store one identity and 10 user IDs & passwords for free. There is no need to auto-start the program with Windows if you integrate the thin toolbar with your browser.
  5. 2014/04/30
    DPI Graphics
    Thanks Guys.
