connection refused
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by sansoo, 2003/04/22.
  1. 2003/04/22
    sansoo
    sansoo Inactive Thread Starter
    I recently installed Netscape 7.2 under Windows 2000. I can receive my email with no problems. But can't access web pages. For any URL, I get the message, Connection was refused by (name of URL). I did not have this problem with Netscape 4.79. Any ideas what's wrong and how to solve the problem?
  2. 2003/04/22
    Ramona
    Ramona Geek Member Alumni
    Welcome to the Forum, sansoo!
    Hi sansoo,
    Check your proxy configuration settings:
    Edit | Preferences | Advanced | Proxies.
    Select: "Direct Connection to the Internet"
    Unless you do have a proxy setup.
    If that doesn't work, then temporarily disable your Firewall, to ensure that it is not prohibiting your browsing.
    Post back if you continue to have problems.
    Ramona :D
    sansoo
    Thanks, Ramona. Thought I had checked that, but........
    Nonetheless, problem solved. If only all Netscape problems were that easy to solve.
  5. 2003/04/22
    Ramona
    sansoo,
    I hear that! ;)
    Ramona :D
