connection refused-NS 7.0
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by lbfoto, 2003/06/08.
  1. 2003/06/08
    lbfoto
    lbfoto Inactive Thread Starter
    I keep getting "connection refused" dialog box when home page is downloaded and when trying to use bookmarks.
  2. 2003/06/08
    Ramona
    Ramona Geek Member Alumni
    Hi ibfoto,
    Check your Proxy settings located at:
    Edit | Preferences | Advanced | Proxies.
    You should have "Direct Connection to the Internet" selected unless you really do have a proxy setup.
    Temporarily turn off your Firewall to see if it makes any difference.
    Rename your C:\WINDOWS\HOSTS file to HOSTS.bak, and see if this makes a difference.
    Let us know if you continue to have problems.
    Ramona :D
